chimney question - Forno Bravo Forum: The Wood-Fired Oven Community
chimney question
  • chimney question
    Does anyone have a close up top view of the chimney opening being built into the dome oven? Size for opening on a 41 inch dome oven, or at least real good picture of the installation process.
    Bill
    Photos Re: chimney question
    (M) I'm not sure if the following link will serve your purpose but try:
    http://www.fornobravo.com/forum/photoplog/index.php?c=4
    (M) Here is a source for my own solution:
    http://www.fornobravo.com/forum/f21/...t-5-a-290.html
    (M) My vent picture seems to have been removed from the photoplog.
    http://www.fornobravo.com/forum/f21/...t-6-a-413.html
    Here it is, again:
    http://i14.photobucket.com/albums/a3...tovepipeal.jpg
    [IMG]file:///C:/DOCUME%7E1/Marcel/LOCALS%7E1/Temp/moz-screenshot-182.jpg[/IMG][IMG]file:///C:/DOCUME%7E1/Marcel/LOCALS%7E1/Temp/moz-screenshot-183.jpg[/IMG]
      Hi.
      I have a few pics of my progress at that point, and could post more if helpful. The opening in my arch is (from memory) 3" x 14". It was actually a little wider than the flue pipe I got and I had to fill the edges a bit. I wanted a smaller opening than the flue itself, after reading about Rumford fireplaces and smoke accelerating through a smaller opening into a larger one.
      I don't think I get smoke coming out the front of the oven, and I don't even have a draft door. Interesting because before I put the flue tiles on, smoke just poured out the front. I need to use acid to clean those bricks so that I can truly see if I have any smoke escaping. I'm very happy with it.
      I found the flue tiles were much cheaper than chimney pipe as well. Spent something like $70 on the whole chimney.
      Vertical pic's of opening:
      http://www.fornobravo.com/forum/f8/s....html#post6451
      Horizontal Pics of flue pipe going in
      http://www.fornobravo.com/forum/f8/s....html#post6471
      - JC
