42" in Hungary by Slovak guy ;)
  • #31
    Re: 42" in Hungary by Slovak guy
    If it were me, I would stagger the joints on the entry vault.
    • #32
      im sorry.. what do you mean?
      • #33
        Cut three bricks for the second course and all alternating courses so joints do not line up.
        If it were me, I would move the inner row of entryway bricks to the outside of the entryway to change the line of thrust and act as a buttress.
        • #34
          This is too complex english for me, im sorry, its not my mother tongue.
          Would you please draw, perhaps? Thank you
          • #35
            Many of the UK, Aussie, and Northern US members of the forum would say that English is not my native tongue . But, here we go.
            Arrow #1 in the picture is pointing to what I meant by staggering the bond.
            Arrow #2 in the picture is pointing to the bricks that GianniFocaccia is referring to. I think that those are just placed there temporarily to hold up your vault form. Correct me if I am wrong. But, a segmental arch will need some buttressing. That is what is what GianniFocaccia meant by moving them to the outside.
            But, now after looking a little closer. I don't see where you are building what we call an inner arch . That is usually built with the dome and the entry arch is built separately. By doing so you will create a reveal to help seal your insulated door. Maybe, a pic of the inside of your entry will help.
            • #36
              Damn, yes.. i was staggering all the bonds, and when i saw my own picture i sweated. Damn damn.. i need to remove those two brick and rework it somehow before it is too late.
              Arrow two: those are temporary brick, holding valt in place.
              Also understood about inner arch, will try to figure out how to build it as a next step. Something like this, right?
              Please explain me what GianniFocaccia said
              "If it were me, I would move the inner row of entryway bricks to the outside of the entryway to change the line of thrust and act as a buttress."
              What is buttressing in general
              "But, a segmental arch will need some buttressing."
              maybe a picture?
              Thank you a lot
              • #37
                understand now.. just realized the force vectors for rounded enry and 'segmented'
                So i need to reinforse the side, because those can fall to the sides, right?
                • #38
                  Exactly what Gulf and GF are talking about. Your build is progressing nicely. English is my "mother" tongue be I can't even understand it some times
                  • #39
                    As Russell said, your oven is coming along quite nicely. You are not too far along to change your entryway design to a hemispherical one, especially if you construct your oven arch that way (highly recommended).
                    Here's a pic of what the forms would look like.
                    John
                    • #40
                      Update
                      Will do inner arch first, and will probably disassemble the arch
                      Also realized i have slightly deeper entrance than usual, is it ok?
                      • #41
                        Looks like you have a reveal, so good. Gulf build has a deep entrance as well and he has had not issues but he can give you his take on it. You are at a point you can start a tapered inner arch like the pictures you showed in a earlier post. Here is a picture from Mr. C showing a tapered inner arch on an inner arch like yours. Looking at your pictures you have enough insulation running past the vent area to bolster you vent arch with no problem.
                        • #42
                          The entryway depth will be fine. You work the fire and pizzas with a long-handled peel anyway, so what's another 6"?
                          A deeper entryway is beneficial against wind.
                          • #43
                            18inches to the door/innet arch point
                            • #44
                              few hours today after work
                              inner arch is done
                              • #45
                                Slovakia guy,short long they all work .
                                Mine is 8.5"
                                My 36" pompai is 2 years old now.
                                Enjoy, DJ Lubetich
