Suggestions for a paint/waterproofer for the dome? - Forno Bravo Forum: The Wood-Fired Oven Community
  • Suggestions for a paint/waterproofer for the dome?
    I have rendered the dome and soon I will need to waterproof it and paint it as I don't want to stick with the render colour. What are people using for this?
    Keep in mind that I have fired the oven several times and due to the insulation blankets I used the outside of the dome doesn't get any hotter than 40-50C degs so I don't need a product that can withstand high temps.
    I would also like the product to fill any hair line cracks in the dome.
    Cheers in advance for your suggestions.
    Re: Suggestions for a paint/waterproofer for the dome?
    I used Drylock for the simi-flat roof of my saferoom. I think that it only comes in white, but you might be able to add a color additive to suit your tastes.
    joe watson
    My Picasa Web Album
      Hi Dan,
      The good thing about using render/stucco is that you can use natural pigment. I use a light yellow to keep the dome cool from our hot summer heat, dark color absorb heat and get quite hot.
        I was gonna suggest Drylock. That stuff stops running water seeping into basements!
