Vermiculite board as floor insulation - Forno Bravo Forum: The Wood-Fired Oven Community
  • Vermiculite board as floor insulation
    Hi
    Does anyone know, if it's possible to use 2" Vermiculite board as insulation under the firebrickfloor instead of FB board?
    Jesper
    Re: Vermiculite board as floor insulation
    Five inches for vermiculite insulation. The "board" would be a cast of vermiculate and portland cement. My insulating layer looks a lot like a fat board.
      I don't think that one has been done before, but it could possibly work. The manufactured Vermiculite board will be better than Vermicrete, but i'd say you'd be better trying to find the Tech Spec and then making your own informed decision based upon Temp ratings, U values, etc.
      Please post any information you find, as it will always lead to furthering of knowledge!
      Ciao!
        Vermiculite board is a pretty old-fashioned material in the states. Jewelers used to use it as a soldering board. I think (this is just a guess) that the binder is waterglass: there's nothing concrete like about the stuff. It should work fine, but I think you will need more than two inches. It's not as effective as cal-sil or mineral fiber board.
          Originally posted by jesperfl View Post
          Hi
          Jesper
          Hi Jesper
          I used a 1" vermiculite board over 4 or 5" of vermicrete - with a thin layer of sand mixed with fireclay to level it. So far I haven't had any problems but it is exremely brittle while you are handling it and will break like a biscuit (read cookie) - but once in place it seems to sit OK. I finally trimmed the corners off last week while doing the stucco finish on the dome. I'd say the ceramic board is more efficient - and I intended to use that but couldn't find any here at the time.
          good luck
          Aidan
          Amac
          Link to my WFO build
            I see that you are from Denmark. I am planning a build here and have started searching for places to buy materials etc.
            Is it because you cannot find the FB board in Denmark, and are looking for substitutes??
            This place sells the ceramic fiber blanket (Insulfrax, similar to FB blanket). Maybe they also sell FB board? I have not enquired about prices yet. If you contact them, I would be very interested in prices ;-)
            Norisol - Insulfrax H?jtemperaturisolering
            Ulrik
              Hi
              Thanks for all the replys
              I contacted a oven specialist, and it is possible to use vermiculite board as floor insulation.
              His suggestion was, 1" of vermiculite board on top of 2" leca blocks, that should be sufficient and much cheaper then fb board.
              Hej Ulrik you are more then velcome to contact me I have prices from many of the dealers in Denmark and some good ideas where to by what.
              my number is 24450966
              thanks Jesper
