dsm Build.
  • dsm Build.
    This is where i am at with my build, just got the roof done today.
    Picasa photo library:
    https://picasaweb.google.com/1043493...lleryMay192012
    Re: dsm Build.
    Very nice
      Re: dsm Build.
      Hey - do I see a hair line crack? Just kidding, great work and you are going to be very happy with it.
        Re: dsm Build.
        Looking good! Curious how you are planning to finish/flash that chimney. I am building a similar design and am a bit perplexed about that one. Looks like you've got the roofing on with no flashing yet?
          Re: dsm Build.
          Haha tell me about it i was freaking out before, i was just installing the roof today and i thought i was gonna have to take it off to fix the crack. But i guess its ok Thanks for the complement Les.I cant wait to make that first pizza.
            Re: dsm Build.
            Hey deejay i didnt really know what to do thats why i left it for tomorrow. Tomorrow i will think of something on how to put the flashing on, then i will post the result.
              Re: dsm Build.
              Just finished the flashing next is the stone..
                Re: dsm Build.
                Hi i have a question i am going to stucco the section of my oven with the wonder board and the arch i am gong to use brick, the thing that concerns me is that the smoke that occasionally come out the oven will it soot up the light colored stucco that i want to put there..
                Thanks,
                Dave
                  Re: dsm Build.
                  ????????????????? anybody
                    Re: dsm Build.
                    There is not much you can do about it, really. Seal both the arch and the stucco with a penetrating sealer to make cleaning easier.
                      Re: dsm Build.
                      Dave,
                      As was mentioned, not much you can do about it. I suggest you finish the front with the brick you have used. It will still get exposed to soot but will not show as bad. I am contemplating raising my vent, not for draw, but on fire up the smoke gets pushed back down from my vent cover and lands on the stucco finish of the dome. You will not have that issue. Your overhang may get exposed but you can cover that with many things that can be easily washed.
                        Re: dsm Build.
                        You could also slice the same brick thin and face the oven with that, it will show less soot than stucco, but sealing in either case is your best bet.
                          Re: dsm Build.
                          Or just live with the soot. I don't find the soot buildup unattractive. I think it adds to the "old world" charm of the oven.
                            Re: dsm Build.
                            Are you using a blast/draft door? They help the oven heat up faster, and channel the smoke up the vent. I can't decide between SS and Neoceram... in the meantime, I'm using a piece of cal-sil wrapped in heavy aluminum foil (my temporary bake door) shimmed up and tilted back in the entry.
                              Re: dsm Build.
                              Yea im might just go with stone like i have on the bottom half and then stucco the sides and back, then seal the front of it like tscarborough said ...ok thanks for the replies - much appreciated..
