Oven door ? - Forno Bravo Forum: The Wood-Fired Oven Community
Oven door ?
  • Oven door ?
    When should a oven door be used, is it for starting a fire or just holding temp in..sorry for the silly question but i really dont know
    Picasa photo library:
    https://picasaweb.google.com/1043493...lleryMay192012
    Re: Oven door ?
    Dave,
    They are used for baking to retain the heat after the fire is out. There was a reference to a "blast door" (on one of your threads). Those are used when you start a fire. It allows enough air in to keep the fire going and sits in the entry. I haven't seen the need for one of those yet but you never know.
      Re: Oven door ?
      I use mine after cooking pizza to retain the heat and later, to keep the dirt daubers out of the oven.
        Re: Oven door ?
        Oh i see,,i guess i will be fabricating one cause i def want to start making some bread once i get to know this oven ...Does anyone have a pic of one that was homemade?
          Re: Oven door ?
          .062 aluminum filled with loose vermiculite - does a pretty good job and it's LIGHT
          http://www.fornobravo.com/forum/8/le...html#post49394
            Re: Oven door ?
            Mine is heavy 17 pounds, but I can cook ribs (240 F.) after 6 days.
            It can be viewed in my post "Chip's 42 in Minnesota" it is 4 inches thick FB board inside stainless and aluminum.
            I will be building a glass door for use when baking bread and other foods so I can see in when cooking.
            I believe a well fitting and insulated door is one very important Key to heat retention.
            Chip
            Chip
              Re: Oven door ?
              Here's my door; works great and nearly 5 years old:
              http://www.fornobravo.com/forum/f9/k...door-3118.html
              Ken H. - Kentucky
              42" Pompeii
                Re: Oven door ?
                Ok great, i do have some heavy gauge sheet metal and 2" fire blanket left over maybe that will do the trick.
                  Re: Oven door ?
                  Here is the oven door my son in law and I made. Just using a metal brake to bend stainless steel and ss rivets. It is just wide enough for a leftover piece of the insulation board that was used under the oven floor. Then, I took piece of ss to my welder guy, who welded it all shut. Notice the feet, which keep it from falling back towards you, and the two handles for easy moving.
                  http://www.fornobravo.com/forum/atta...112_092508.jpg
                  Tom
                    Re: Oven door ?
                    Thats a good idea tom, nice job.
                      Re: Oven door ?
                      My thought process has been to use refractory cement and perlite. I am on door number 4 and it has been working well. If you scan through the latter pages of my build thread, http://www.fornobravo.com/forum/21/begun-8852-25.html , you can see all of the attempts.
