interior surface of bricks - Forno Bravo Forum: The Wood-Fired Oven Community
  • interior surface of bricks
    I have some mortar that oozed out beyond the bricks and I took a grinder to it but touched the surface of the bricks making some shallow gouges/scrapes. I've read when building the oven to keep the non cut side of the bricks facing the inside of the oven. What's the significance of this practice?
    How is the performance or effectiveness of the oven affected if the interior surface is not factory finish?
    Thanks,
    Nate
    Re: interior surface of bricks
    Thanks,
    Nate
    Doesn't affect the performance. As far as I know that's purely aesthetic flaw.
      I hit a brick with a grinder as well and smoothed them with course wet and dry sand paper (wet with water) - worked well.
      Brett
        while sorta on the topic
        I've always wondered, if you are using second hand bricks, for example out of an old fireplace (say 30+yrs old) and their outside edge is blackened - would it pose any risk for a pizza oven? I mean from toxins or whatever crap was burnt in the fire and subsequently went up the chimney and possibly deposited on the bricks themselves
        Worst case I guess is just put the cut side inwards
        just wondering.......thoughts?
        Damon
        Build #1
        Build #2 (Current)
          i would guess the smoother surface is just cleaner. The smoother surface has fewer cavities to catch particulates that might fall in your food and gunk up the dome. fwiw.
          Tracy
          Texman Kitchen
            This was a concern when I was searching for used bricks. I was worried about bricks used in a commercial enviroment where various metals were in contact with the bricks. I guess buying bricks from a residence would not be as big of a risk. But decided to buy new bricks because they werent that expensive.
            Nate
              Well that's it domestic would be relatively low risk...... I guess with a few decent fires pre cooking most of whatever might have been there was burnt off.
              Damon
              Build #1
              Build #2 (Current)
                Thanks,
                Nate
                The plans talk about laying the bricks with the cut side out, but purely for appearance. I managed in my fatigue on a couple to do just that, but after a few looks in the oven, it doesn't look bad at all - just "rustic" and I can't see how it would affect performance in the slightest. More worrying is the impact of grinding - how does that vibration throughout the oven affect the integrity of the mortar? If anything, I'd be leaving the grinder out of it. One advantage of using refractory mortar vs home brew is that it takes a very long time to go really hard so you can clean up for some days afterwards.
                (see, now that I've closed my dome but yet to complete the whole oven, I'm an expert. :-) )
                JT
                Willetton, Perth
                Western Australia
                My build: http://woodfiredovenperth.blogspot.com.au/
                  Yeah, yeah, JT. We're all experts after we complete our ovens! Funny!
                  I read here that bricks don't actually vitrify when they're fired, but do take on a hardness on the perimeter of the brick that is sometimes not obtained in the center of the brick. I think this is the reason behind placing the cut side out.
                    Pretty much every brick in my dome has the cut exposed to the fire (it looked very clean going that route). Been using it for about 4 years now and no problems whatsoever. My biggest concern was spalling since I didn't use mortar - that hasn't happened either. (knock on brick)
                      For firebrick, no problem, but I would try and avoid it when using solid commons as there is a distinct difference in hardness between the outer 1/4-1/2" and the inner brick.
