Rough count of Firebricks for 42" oven - Forno Bravo Forum: The Wood-Fired Oven Community
  • Rough count of Firebricks for 42" oven
    I'm assuming that being such a common size to build there is a pretty good idea of how many firebricks are necessary to complete a 42" dome. I am in planning phase, and thought I should check here before ordering.. I tend to buy overboard because I use them for the next project, but a rough idea would be good.
    Thanks MAtthew
    Re: Rough count of Firebricks for 42" oven
    Download the FB plans, they are free and have been used enough to have a pretty refined count.
      About 200. Depends on if you taper them.
      dusty
        You could also try deejayoh's calculator, which will take tapering into account: http://www.fornobravo.com/forum/f28/...tor-18131.html, which will give you a rough count of the needed bricks. Add a couple dozen more bricks on top of what the calculator says so that you have enough for your entry and vent. I used nearly 200 full bricks for my 36" oven (including the floor and vent), but I tapered my arch and dome bricks.
        My build: http://www.fornobravo.com/forum/f8/3...-dc-18213.html
          No its late, but for what its worth I bought 250 bricks and used most of them. Good luck
          http://www.fornobravo.com/forum/f8/p...s-i-18098.html
            I came in around 275 - a ton of scrap...
              I used 280 with a a 1/2 ton of scrap and 1/2 ton of fireclay.
                I used 280 and tapered all of the dome bricks with the exception of the soldiers..
                Chris
                  Gudday
                  42in Dome only (entrance commons) not tapered basic cuts only...count 165
                  Regards Dave
                    210 and counting on my 36". I think I'll need maybe 10 more before I'm done, but I have a good many scraps lying around.
                      I used about 235 firebricks for 46" oven, All tapered.
