My 40" Inch pizza oven in Florida
  • brickie in oz
    Re: My 40" Inch pizza oven in Florida
    You spelt July wrong........
  • kbartman
    Originally posted by SCChris View Post
    The idea is of course to go to the target temp and hold for enough time to saturate and give the structure time to get comfortable at temp.
    Be gentile with her until you get acquainted..
    Remember your in the cooking range at 350F and a roast chicken can be a great reward..
    Chris
    Thanks Chis,
    I will be gentle with her, as I would my wife. I brought the oven gently up to 350 before leaving it to the wife to tend. I went inside to sleep to be ready for night shift. I was hoping to keep the oven at 350F all day. When I woke I discovered she had left the temperature fall to about 250F. Oh well no chicken supper for me. Try again tomorrow.
    I scored some free fire wood from a friend, I should be good to go. Mostly oak. He did say there was some other tree mixed in he had cut down in his yard don't remember the name, started with a "M", I think. I couldn't tell the difference cause most of the bark was off.
    Anyway I was wondering is there any is wood that is poisonous to burn?
    I will have to find out the name my friend's tree.
    Took some pictures of the dome to look for any crack. Don't see any yet.
  • SCChris
    I don't see your durations at temp on day 2 and 3, but considering the first day I think your good to gently push, over a 2-3 hour time, to 300 and hold for a few hours. After 2-3 hours or so at 300 you could bump to 350F and again hold for a few hours. This should be more than good for day 4.
    Day 5 could slowly build, over a 3-4 hour time, to 450F and hold. Add a 100-150F a day to 700-800F. At 800F your oven isn't completely broken so don't assume that you can push it from ambient to 1000F in 30 minutes and without cracking something.
    Chris
    PS. Remember as the structure dries the amount of fuel needed to get to and to hold temp will decrease and this can very easily take you by surprise when you shoot well past the target temp.
  • kbartman
    Ok Guys,
    I finish day three of curing. I been taking it slow. The first day about 1 pm and went for about 12 hours Holding the dome top temp at 200 F with IR thermometer, had a few spike at 230F. Hit 250F before bed and let her cool. I wasn't to concerned about the few spikes cause of the pre-curing with the 1500W of light that held the temp at about 165 F for many days
    Day 2:
    Worked on insulating the dome so tending the fire was on back burner so temp swung between 165 F to 243 F. I was keeping a eye on my top TC which is located about 1 1/4" above top of dome face. I hit 212 F before going to bed so I decide to let her cool.
    Day 3:
    With dome insulated I began with the following measurements: I did not have time to maintain the fire but ask the wife to add a few piece charcoal about every 1/2 hour or so, and don't let the top TC to get above 210F
    .............................Start ............... Mid Evening
    Top TC:...................158 ...................210F
    Side TC:...................129F..................161F
    Side outside
    of dome TC:..............120F..................132F
    Top IR .....................164F...................245F
    Side IR ....................140F..................195F
    Floor IR ...................118F...................157F
    I hope to go above 250F upwards to the 300F mark tomorrow. What do you all think?.......... I'm scared need opinions.
  • kbartman
    Originally posted by boerwarrior View Post
    Looking great, KB!!! I predict that you are going to be very, very, happy with your oven!
    Neil
    Thanks Neil,
    I'm sure and also predict I will be a happy man, especially when all the hard work sweat and tears are over.
    I carried these posts back from GarnerAC thread and one on thermocouples hope to continue the discussion on dampers and gadgets.
    Gac,
    Sounds like your sticking to simplicity. I understand, my thinking keeps me going over budget, I keep trying to simplify my life but there is away a new project around the corner.
    I'm on my third day of fire curing. Keeping temperatures low is a task especially after the addition of insulation. I will try to post some data on the temperatures of thermocouples later on my thread.
    Since it sound like simplicity is in your future and we don't want to high jack your thread. I will post more comments about dampers and gadgets on my thread.
    Hope your surgery goes well.
    I also fell in love with the thought about dampers and gadgets after seeing Gulf's excellent build. I considered a damper on the flue as well. I'm curios to hear from Gulf on the utility he has found with his............... I'm still considering, but in the interest of speeding my build I left it out of my chimney, I'm thinking of maybe incorporating it in my stainless steel chimney extension\spark arrestor. Although Over dampering on the chimney could cause smoke to come out the front of the vent area's outside door............... I thinking some type of temperature\damper controller might work better work on the inside oven door.
    I have been mentally toying around with the idea of an inner door with a PID-controlled regulator/fan and two openings in order to use the oven as a smoker/slow cook BBQ. I am not sure it would work, but it would be cool to be able to maintain temps of 200 or so for long periods. Adding an outer door and a damper to that equation seems like it would make it a more complicated task.
    Cool idea Dee I hope to purchase a PID controller to display my temperature read outs.
    I found this temperature controller to use as my thermocouple read out.....Autonics TC Series PID Temperature Controller | Temperature Controllers | Instrumart What you all think?
  • boerwarrior
    Neil
  • kbartman
    Hi KB
    I have been in contact with a commercial oven builder, that builds commercial furnaces . His practical over 30 years experience told me. Finish the oven completely then cure. that's what I will do.
    Btw. Looking good. A picture of your Thermo couples would be great still contemplating that one. Also any cracks appear?
    Colin,
    Sorry no picture of the thermocouple. It is just some scrap thermocouple extension wire twisted together to form the measuring junction and then taped with high temperature glass tape the first foot. I'll take a picture on the next one I make.
    Sorry no cracks its all covered with insulation now.....I guess I'll never know.
  • oasiscdm
    Hi KB
  • kbartman
    Ok Guy's
    I'm finally curing the oven........... Added some thermocouples to help with the curing process and to play with later. I have been trying to hold the dome top at 200degrees today.
    I'm pretty sure I want to finish insulating the dome before I go to the higher temps................... What are you'all thoughts?
  • kbartman
    hey KB looking good.
    Thanks Colin.
    Anything made with Portland cement will benefit from being kept moist for a week to increase strength.
    I think I'll wait the seven days and go easy then. Neat testing David, Thanks for your input.
    I got some insulation around the chimney. That is some nasty stuff. We will have to do a study in about 25 years and see how many WFO widows there will actual be........... I used a respirator, I think next time I'll were a Tyvex suit. I was thinking of putting the insulation on the dome for curing then remove on inspect for cracks. I don't think I want to do that,........... It's to nasty.............. Also I got all the studs cut for the chimney surround..............
    Anything made with Portland cement will benefit from being kept moist for a week to increase strength. If you are not concerned about strength then it doesn't matter. Removing the water though, can be problematic because steam will rapidly increase in volume and can make the vermicrete layer expand and crack destroying the bonds that the cement made. As the vermicrete contains around double the amount of water than the same volume of normal concrete removing that water can cause problems.I like to let time and the weather do much of the drying, but this depends on what Mother Nature dishes up to you. I did some tests with vermicrete that may help.
  • oasiscdm
  • kbartman
    I lit the first fire in mine about 15 minutes after I pulled the arch form out. Just build the heat slowly and you are good.
    I would give the portland in the vcrete at least 7 days to cure before firing.
    No one get there panties in a wad, but couldn't wait........... It's official, first fire......although just a draw test on the flu, a wad of paper........... I think I will let her rest and cure while I work on insulating and the enclosure.....................
  • Tscarborough
  • kbartman
    Bummer ..............................its going to be a long wait
