Curing oven - Forno Bravo Forum: The Wood-Fired Oven Community
Curing oven
  • Curing oven
    Should I cure my 42 inch Pompeii before I install insulation or after I have read of people doing it both ways?
    Re: Curing oven
    Like you said people go either way. But what type of insulation you installing? Igloo or enclosure? Cladding? Lots of variables. I cured without insulation but your case could be different.
      Re: Curing oven
      I am using ceramic fibre insulation and plan an igloo style finish. The oven is under a roof so I'm not worried about rain.
        Re: Curing oven
        What are covering the CF with?
          Re: Curing oven
          Stucco. Thank you for responding. I have been reading your build and many others for years and now finally had time to build my own
            Re: Curing oven
            My plans are just like yours. I plan on curing and having it full blast before i put the insulation, because i can see how the oven performs, if it cracks, or i should say how much it cracks etc.
              Re: Curing oven
              One thing that was suggested when I cured was to loosely cover the dome with the CF while curing to help equalize the the temperature from the inside to the outside. I did not out of forgetfulness but not a bad idea and nothing to loose.
                Re: Curing oven
                Thanks again for the quick response. On another note I have several lengths of black stove pipe from an old wood stove could I use this for my chimney?
                  Re: Curing oven
                  I'll defer that question to others who used single wall pipe. I used Selkirt double wall SS pipe.
                    Re: Curing oven
                    I'm either going to use a single walled pipe or no pipe, just vent it out with a red brick chimney. I am not paying $$$$ for a double walled pipe. Thats just me.
                      Re: Curing oven
                      That's exactly my thoughts. I'm sure my wood burning stove gets hot than my oven will. I can't see spending more on the chimney than the rest of the oven
                        Re: Curing oven
                        Gudday
                        I read an English build and his using an enameled single steel pipe. Sounds more durable than plain steel but is it available , I'm going to be keeping my eye open for that it sounds usable?
                          Re: Curing oven
                          Just back from the hardware store 3 sections of chimney for 50 bucks. Will be installing this week.
                            Re: Curing oven
                            Gudday
                            Isnt enamel just the finish? If so you can even apply engine enamel from a spray can.
                              Re: Curing oven
                              Gudday
                              I think it's dipped and then oven baked. I don't know about engine paint would it be hard to spray the inside of a 6 in steel tube. I now have a mental picture of someone's arm up the elbow in a steel tube with a spray can. Recon one of those gloves that they use to inseminate cows. I'm not letting this thought go any further.....
                              Regards Dave
