oven opening widht and arch form - Forno Bravo Forum: The Wood-Fired Oven Community
  • oven opening widht and arch form
    Hi,
    I am begining my opening arch, due to brick size I have 2 options for the opening:
    1. width - 500mm ( 20") hight- 280mm (11")
    2. widht - 430mm ( 17") hight - 270mm (10.6)
    My oven is 36" with dome of 18" high.
    I know the difference between the options are not so big, but I want to make sure that from one hand the oven will be efficient as possible (smaller opening) but on the other hand convenient for working.
    what do you guys think?
    regarding arch form, after deciding the final size I'll cut my form out of plywood, should I take in consideration the space for the mortar between the bricks? ( Im worried that after mortaring the bricks the final arch size will be larger due to the space taken by the mortar)
    Thanks,
    Eyal.
    Re: oven opening widht and arch form
    Im sorry but what does brick size have to do with opening size?
    Your opening can be what ever you need it to be regardless of brick size.
      Hi,
      Thanks for your quick replay, my bricks are angeld and i do not want to cut it again, but it is less importent,
      What do you think about the sizes?
        18" dome height x .62 for the golden ratio gives you 11" door height.
