Installing Insulation Board - Forno Bravo Forum: The Wood-Fired Oven Community
  • Installing Insulation Board
    I am building a 42" Pompeii WFO using the plans that FB provides. The plans go into detail with the Vermiculite method and applying a thin underfloor paste for the cooking floor. It also shows a insulation board placed on top of a wet hearth. My hearth is dry. MY QUESTION: If your hearth is dry and your using insulation board, is it OK to just place the board down and then place the 18" x 18" bricks on top? This means that the igloo is just "floating" on top of the hearth and there is nothing sticking it in place. I guess the weight would keep it all in place but not sure how to proceed. If I need to level things what should I do in this situation. I hope the board comes very flat??????
    Greg
    Re: Installing Insulation Board
    Greg,
    You can level the board using some dry clay and a notched trowel. You may have to shuffle them around a bit to get it level. Just sit the floor tiles on top - trust me, it will not go anywhere.
      I did the same all dry and my floor bricks were suprisingly level
        The problem is that the firebricks for the floor are often of an uneven thickness. The clay layer under them (wet or dry) allows you to achieve a flat floor surface. Usually the mix is a 50/50 sand, clay layer.
