A New Journey
  • #16
    Re: A New Journey
    here is a pic of my oven placement
    • #17
      Re: A New Journey
      The blades just got here today. I hope they perform well I may cut a few today just as a test. More to come...
      Loren
      My Build - http://www.fornobravo.com/forum/f8/n...ney-19648.html
      SLOB - Salt Lake Oven Builders - For WFO builders in Utah - Join here http://www.fornobravo.com/forum/grou...-builders.html
      • #18
        Re: A New Journey
        Obviously that image was too large and I won't do that again... but I can't figure out how to delete it... I deleted the attachment page but the image won't go away... suggestions?
        Loren
        • #19
          Re: A New Journey
          Had to edit the code of the website within Chrome to remove the picture... Looks like it is back to normal. I'll have to adjust the image size if I want to imbed the image again.
          Loren
          • #20
            Re: A New Journey
            MK blades are great and you should get through the whole build with only one. Let the saw do the work and don't push the brick through too hard....#1 mistake I see during wet saw use.
            Old World Stone & Garden
            John Ruskin
            • #21
              Re: A New Journey
              Is the one one the right a dry cut blade?
              EDIT: Nevermind,...I see that it is a gen purpose, wet/dry.
              John Ruskin
              • #22
                Re: A New Journey
                I've heard great things about them. The black blade was a bit pricey and is supposed to be for refractory brick and the other blade was a $25. Of course I started with the more expensive blade and it cut very nicely. Didn't have to force it at all.
                The only issue I've seen is that I have monster blocks so it takes about 4 passes to get the bricks to their intended use size which is about 4.5x2.5x9.5 or half of what they currently are. If I remove the water guards on the saw I could probably do it in 2 passes which would save a considerable amount of time and block turning.
                Here is a picture of the half size blocks next to an uncut monster block.
                Loren
                • #23
                  Re: A New Journey
                  Did you consider renting a cut-off saw for those big brick? You could really rip through them faster than with the table saw.
                  John Ruskin
                  • #24
                    Re: A New Journey
                    Loren,
                    That's alot of cutting. Before you cut too many, see how many lower courses you can just cutting the 9.5" depth in half. The angles are less severe on the first few course and you may not need to do alot of fancy dissecting of the "big bricks". The darker brown bricks I gave you I believe are 3" thick so maybe work them in the second phase of the course then you can see how many big bricks you need to rework to the 2.5" thickness. You can also use smaller taper bricks (the light tan) as well in the upper course IMHO. It is like a jugsaw puzzle, sometimes you need to step back a few feet and look the the big pic.
                    • #25
                      Re: A New Journey
                      Thats a good Idea. I'll have to look in to that
                      Loren
                      • #26
                        Re: A New Journey
                        Loren,
                        Yeah I was thinking about just doing the first 2 courses by just cutting the large bricks in half and using that and then using the Smaller ones we'll see... I have quite a lot more to do before I even start thinking about the dome so these really were just tests to see if it could be done. the option of a large chop saw is good. I have a friend who is a professional mason so I might hit him up to see if he has a 14" chop saw that he might let me use for a day or something.
                        Loren
                        • #27
                          Re: A New Journey
                          Well I have put the oven on hold for now. I hope to do the base before the winter but I probably can't start the dome till next spring. I have too much to do in the yard with sprinklers and what not right now but I'll post updates for all my oven related activities.
                          Loren
                          • #28
                            Re: A New Journey
                            Well it's been a while since I have dedicated any time to this but it has been for good reason. I was able to do all the sprinklers in my yard and lay the sod in my front, plant a few trees, build a boulder retaining wall and fill all the holes in the back yard (.5 acre) so now I'm ready to start the project.
                            During my relax time I threw together a 3D rendering of what I'm looking to do. This picture is missing the pergola over the whole thing but what are your thoughts of the plan?
                            For those following me... I decided to put the oven a bit away from the house in the far corner of my lot and integrate my grill island and create an entire space for outdoor entertaining.
                            I'd love to hear some thoughts and suggestions.
                            Loren
                            • #29
                              Re: A New Journey
                              Here is the idea with the Pergola and the built in table ... I'm planning to do a large rectangular farmhouse table but this round one had to do.
                              Loren
                              • #30
                                Re: A New Journey
                                Your back yard is bigger than my whole lot!
