IT without welding? - Forno Bravo Forum: The Wood-Fired Oven Community
IT without welding?
  • IT without welding?
    I want to make an IT, but don't have a welder. I have made a very crude one out of a door hinge, wood strips (for the arm) and a door bracket. Curious if there's anything out there that's better. How'd you make yours if you didn't weld? A link to your build would be great.
    Here's mine:
    http://www.fornobravo.com/forum/f8/j...man-15992.html
    Re: IT without welding?
    Anyplace where welding can't be replaced with bolts it can be with JB weld.
      Buy 2 part epoxy let it sit over night and your good either 3m duramix or sem all available just as strong they sell small tubes
        jimkramer
        another method is to use a length of threaded rod with a couple of nuts, adjustable and strong!
        Cheers.
        Neillís Pompeiii #1
        Neillís kitchen underway
          At first I was thinking about doing something like this...
          But I did have mine welded.
          My build: http://www.fornobravo.com/forum/f8/4...way-19491.html
            Just in case you find someone who can weld for you this is how I did mine.
            I have a small hobby welder and no experience with welding but I made it stick
              So why did it need welding?
              It would stay in place by locking the thread up surely?
                Steellearning- how'd you affix the threaded rod at the bottom? It seems people often use either a door hinge or caster. I suppose I could drill a big hole in a hinge, then bolt it in place.
                Here's mine:
                  The bolt was only used to hold the long nut in place during welding and was removed after. I didn't want to have a nut on the shoe side of the bracket (where the brick is seated). Plus I wanted to try welding...
                    This is what it looks like... Hope these photos help explain.
                    Not the most beautiful welding, but it stuck...
                      Countersink a machine bolt through the bracket into a long nut like Steellearning used. Secure the whole thing with some thread locker and/or epoxy. The bracket doesn't need to be all that strong. It just needs to be secure.
                        [ATTACH]37580[/ATTACH]
                        Much better idea, wish I had thought of that...
