Semi- circular openings - Forno Bravo Forum: The Wood-Fired Oven Community
  • Semi- circular openings
    Reading post after post, lots of info in this forum, awesome. Another question I have is in regards to semi circular openings. Is a 20 in wide semi circular opening , which would be 10 in high enough for a 42 in semi circular dome? You could add another 2.5 inches of height to each jamb to get to 12.5 in. Has anyone constructed an oven with these dimensions? I personally like the looks of a semi circular arch.
    Re: Semi- circular openings
    Hi Campmaki
    Amac did a semi-circular entry and it turned out very well. Follow this link:
    http://www.fornobravo.com/forum/f8/3...eii-17334.html
    Sharkey.
      My 42" oven has an 18x8 nearly semi-circular opening. The traditional ovens from Naples use semi-circular door 44x22cm.
        My opening was abt these dimensions for my 42 incher.
          My opening were abt these dimensions for my 42 incher.
          WOW, some of you builders have really impressed me with your masonry/ building skills. What a beautiful oven Mr. Beehiver, outstanding and thanks for the help.
            When you say jamb, do you mean a segmental arch opening? Or are you building a semi-circular arch? Because you can increase the rise by bringing the radial line higher on the center line.
            Old World Stone & Garden
            John Ruskin
              Stoecutter, when I said jamb I meant side. Strike the arch with a string, 10 in. radius then just add 2.5 inches or brick under the semicircular strike. thanks Stonecutter
                My mistake when you have a semi circular arch you in essence do not have sides or jambs as call them. Just would add 2.5 in. ,then put semi on top of it.Thanks again
                  I understand, your spring line for the radius starts 2.5" above the floor.
                  John Ruskin
                    Yes sir, and thanks for the help.
                      "Jambs",............."Carpenter" huh,
                      It's all right by me. I grew up in a carpenter family. We built homes from the foundation up. That meant: footers, slab, septic tanks, fraiming, roofing, fireplaces, wiring, BBQ pits, etc. etc.
                      It ain't easy "meshing" all the "trade names" + the "local terms" in to my posts, as well .
                      joe watson
                      My Picasa Web Album
                        Gulf, actually I am a 32 yr. veteran mason building his first oven. Should be fun and go fairly quick for me. Building it at my summer home on weekends at a campground. Sorry about the construction slang, lol Wayne
                          I also like the appearance of a semicircular opening but I also wanted a large opening to allow me to slide turkeys and beer can chickens through the entry way. So I compromised...
                          I created a semicircular opening on the outer arch (where you can see it) and a shallower arch with vertical "jambs" on the inside to maximize my opening size. I think my inner arch is 12.5" tall x 20" wide (10" vertical jambs) and my outer semicircle is 13.5" tall x 22" wide.
                          Good luck and post some pictures.
                          Regards,
                          AT
