Pompeii Stand Question tumbled block - Forno Bravo Forum: The Wood-Fired Oven Community
  • Pompeii Stand Question tumbled block
    I am considering using a prefabricated block to match a wall in my current landscaping. Does anyone have experience with a product like this?
    Patio Seating Wall Products - AB Courtyard Collection
    I have been searching the forums and don't really find any builds using a block like this.
    This is more expensive but creates a nice look with other things that I will be doing later with my BBQ etc.
    Darin
    I often cook with wine, sometimes I even add it to the food...
    WC Fields
    Link to my build
    http://www.fornobravo.com/forum/f8/4...-ca-20497.html
    My Picasa Pics
    https://picasaweb.google.com/1121076...eat=directlink
    Re: Pompeii Stand Question tumbled block
    I used modular block like that for a friends retaining wall once. It should work fine for a oven stand, but keep in mind most of those wall units are designed to be built on a batter, so plan your footprint accordingly. They might have vertical block too, But I don't use modular wall block, so I'm not sure.
    Old World Stone & Garden
    John Ruskin
      That is a vertical 2 sided wall block, it should work fine.
        So they are..... I guess I should have looked at the pics closer.
        John Ruskin
          Perfect, without showing the actual plan, it will be a similar Square/Rectangle like every other stand with two Pillars in the entry of the space for Looks and for work/counter space. They will be capped and will be 2 - 2x3 foot pillar caps for putting food down etc.
          Sounds like it will work just fine.
          Darin
          WC Fields
          Link to my build
          My Picasa Pics
            You do not have to do so, but I would use a product like NP1 between them. Just run a single bead down the center.
              So what you are suggesting is, take precautions to tie it all together right? I would do that....either rebar and concrete or a combination of glue. What is NP1?
              Thanks for the suggestion...
              Darin
              WC Fields
              Link to my build
              My Picasa Pics
                It's exterior grade construction adhesive.
                John Ruskin
                  Ok so the stand is done. I was able to use the block that i wanted. This took two days to build. It was two full days of work with a bit of Butt kicking. The second day was over the next weekend. Today....a lot saw work. I had to cut the block to fit in a 4 inch Angle Iron.
                  This is what I wanted and it was worth the hard labor haha.
                  Darin
                  WC Fields
                  Link to my build
                  My Picasa Pics
