Concrete Foundation Base Cracked...Damn it!
  • #16
    Re: Concrete Foundation Base Cracked...Damn it!
    My thoughts are simple, put frost walls and footings in, at the beginning. There is not a solution for the cracked slab. Hope for the best, but you can not control the freeze, thaw cycles. How do you put foam under a cracked slab after it is poured? Are you rigging the whole oven and picking it up with a crane? As far as tying the slab to the walls with pins,I would tend to leave it alone as this could make the oven move with the slab.
    • #17
      Ummm.....my suggestion about the foam is to protect it from future damage. If he lays some 2" thick foam around the base next winter, weighs it down, it will NOT freeze again. It may not look nice (you can cover it up), but it will not freeze again. It's not going to do a thing about what's already done, but if he leaves it as is, the foam will work, if he keeps it in place. Always pay attention to the north facing side. It almost always freezes and heaves there first. Also get as much soil around the slab as you can.
      My Build:
      • #18
        Alot of people have the misconception that frost comes up from underneath a slab and does the damage. It doesn't. The ground under a slab is actually quite warm, even in colder weather. The damage comes from outside the slab, along the edges. It gets under an edge, expands and lifts up the slab and does it's damage. I've seen firsthand what frost can do, many times. That's why I have to chuckle a bit when I see people dig down under a slab (before pouring) and place sonotubes, etc., supposedly to prevent frost heaves. Waste of time and money and that can actually be quite detrimental in some cases. All he can do now is to somehow protect it from future damage by keeping the edges of the slab well covered, thus keeping the grounds' natural heat in and the cold out. I've done this quite a few times w/slabs. He also can actually dig down a few inches around the perimeter of the slab and bury the foam, keeping it tight against the slab edges. Then cover it w/soil.Works like a charm. Having said all this, what's done is done and all he or anyone can do is live w/it and take steps to stop future damage. Or.......tear it all down and start over.
        My Build:
        • #19
          That can help if the frost depth is shallow, but in New England I have seen frost reach down deeper than 24" and when it's that cold, the slab drops below freezing along with the ground below it...and foam board won't stop the ground from moving under the slab, especially so if there is a lot of water in the soil.
          Bottom line, it doesn't hurt putting it in, but it won't completely protect the slab from frost.
          Old World Stone & Garden
          John Ruskin
          • #20
            No, it won't completely stop it or protect it, but except in very extreme cases, it works just fine. I have taken out slabs before in the dead of winter, only to find the ground underneath completely normal, although the ground around it was frozen 14" down. We had to use jackhammers just to cut the ground so a backhoe could tear up chunks of ground, which we measured to be frozen 14" solid, yet under the slab was fine. I've seen and worked on lots and lots of "frost cases" in my days. Too many. And they could all have been avoided. And, as I said earlier, properly placing 2" foam around a perimeter of a slab will work in "most" cases. It is only offered as something to try that will probably work, as an alternative to ripping it all out. Nothing will ever take the place of doing it right. One of the best pieces of advice to offer to people planning to pour any slab, is if you have severe cold and/or moisture, have someone who really knows what they are doing help or advise. It's what holds up your whole oven and it's the most important. You only get one chance to do it the right way. Unless of course, you tear it all out, then you get another. Not a place to cut corners.
            My Build:
            • #21
              Originally posted by ncman View Post
              not a place to cut corners.
              +1.............
              John Ruskin
              • #22
                This mans build is in Maine ,right? How far does frost penetrate there? Standard practice in Wisconsin for a stoop, which supports steps is 4 feet of masonry on top of a footing. I do not believe for one minute that frost will not travel side ways thru styrofoam. It still gets cold enough to freeze the ground under a slab. I see sidewalks every spring getting redone because they heave. NC, the climate in your area is a lot different than Maine. I understand the concept to try and say the oven. Anything is worth trying at this point. By the way the frost has gone down 5 feet this winter here, probably close to that in Maine.
                • #23
                  I'm not sure what you mean about frost moving sideways through foam. Anyway....all I was trying to do was find a way, somehow, to save them from having to tear it all down. I have lived and worked in places far north of here (Pa.), so I have firsthand experience w/frost and concrete. I actually am not here to convince you or anyone else about frost heaving, etc, and don't care a whole lot what you believe about it. I was here to offer some assistance to someone w/a problem. That's it. If you think that just because you live where you live that makes you the only authority on the subject, then have at it. As for me, I will continue to offer help to anyone w/a problem.....if I have actual real world hands on experience w/the subject.
                  My Build:
                  • #24
                    NC, are you saying laying down a sheet of 4x8 2in foam flat all the way around the perimeter? I guess I never heard of this way of protecting a slab from heaving. Sorry if i came across the wrong way.
                    • #25
                      That's ok. I'm done giving advice and trying to help. I'll just stick to updating my Build.
                      My Build:
                      • #26
                        there is realy no way to save the base but you may be able to lift the oven off the base. it has to be built on a foundation below your frost line. no insulation under the slab or besides the slab will work. as you see of most of the oven built on here are on thick slabs which is fine in warmer zones but in the north east you are going to have to dig alot further down below the frost line. now this year was a real cold year out of the norm. if you look at where you slab cracked water pooled under the slab the oven base puts the load on the out side of the slab. so with the freeze and melt when the water refreeze it will expand and crack most concreet slabs in the middle. this is why you should use a good 4'' of stone under the slab. ( more stone if you have heavy clay layer. best to remove the caly if possable so water can drain.) above and below your foundation not cheep crushed concreet or modfied as they call it becaus it holds water. the stone alowes the water to drain away faster form the concreet for the refreeze. it looks like you also have a lot of water there. just like a house try to get the water away from the oven. any large amount of water will damage any foundation over time. so at least 4'' of stone on the bottom of you foundation poor and levil 4"" of concreet. then build your foundation either block it or form and poor it. then put at least 4'' of stone on the inside of the foundation. if real wet you may want to put stone around the out side of the foundation. then poor 4"" of concreet on top. then you can start your oven base. with doing all you can to control the cracking. concreet cracks it is just what it does all you can do is try to control it.
                        Otto
