38" build in Slovenia
  • #46
    Re: 38" build in Slovenia
    I think that I used a poor description referring to the entry as a "tunnel". I think that now, since you responded with the term "straight tunnel". You stated "I do not like straight tunnel as I need a lip to anchor outer door to prevent weather getting in." I used face brick on my ouitside arch to form that lip for the exterior weather door. Others have used reinforced stucco to do the same.
    You did a pretty good drawing of your first plan. Could you post a drawing of your new plan? I am not understanding all of what I read, as I am sure that you are not understanding all that I post. Every thing that I see that you have done so far, looks great! I just want to make sure that I have not confused you on the rest .
    Joe
    • #47
      I changed my design on bottom parts of the arch to minimize stress in area marked with green arrow. I turned full bricks vertical to maximize strength after cutting clearance slots.
      Here is my revised plan.
Name:	zunanji vhod2.jpg
      Gorazd
      • #48
        Front arch
        Yesterday I started building front arch.
ID:	305048Click image for larger version
        Midday it was to hot for my mortar (it went in 4 minutes) so I was a bit behind on my schedule.
        Today I finished it.
ID:	305050Click image for larger version
ID:	305051Click image for larger version
        Almost there
        • #49
          Thermal break
          Here are some detailed pictures of thermal break.
ID:	305053Click image for larger version
ID:	305054Click image for larger version
ID:	305055Click image for larger version
          What should I put beneath the stainless U bar on the floor break?
          a) nothing
          b) vermiculit
          c) perlit
          d) leica balls
          e) something else
          Gorazd
          • #50
            Great looking entry! It should draw real well. Again, it is an interesting design. I am looking forward to hear how it performs. After packing the heatbreak, and giving it some support with the vcrete and reinforced stucco, the entry should serve you well. I am guessing, that you will be making the reveal for your weather door out of vcrete and stucco?
            • #51
              Thanks Gulf. I removed forms after only 20 hours of drying and it was ok. Over that I will render with perlite stucco with added reinforcement fibers (commercial product) 1" thick followed by acrilic/silicate stucco or gress tiles, haven't decided yet.
              I will be packing heatbreaks with ceramic rope and hi-temp caulking, but I do not know what to put under floor heatbreak?
              Weather door will be inset into entry so no extra reveal. I will do that in autumn months before first snow.
              Weather forecast is 3 days of rain after that I will start curing the oven.
              My plan:
              - 3 days of 500W reflector on timer(cycling temp) or until there is moisture under tarp.
              - gas burner 5kW until oven reaches 150 deg celsius
              - insulate the dome with 6"-8" of rockwool (660 C / 1220F)
              - add reinforced concrete with vermiculite added to lower weight 1"
              - dry for 1 week
              - add lime/cement stucco 5-10mm
              - dry for 2 days
              - add silicate stucco
              - dry for 1 day
              and then fire this baby
              So I can report how it is drawing smoke in about 3-4 weeks.
              Gorazd
              • #52
                I've never worked with the stucco with the fibers. I have heard some good recommedations for it from this site. I'm an antique so I used the mesh. Are you still applying the stucco over 2" of vermicrete?
                I did not use the ss channel for a heatbreak. I just separated the oven floor brick from the entry brick with ceramic fiber tape. Maybe someone who used the ss steel will answer that for you .
                • #53
                  Dome insulation
                  After curing the oven with light bulb and gas burner I covered the dome with insulation. I used two layers of 4cm (1.6") rockwool over the entire dome with extra 4cm layer over the top. In the pictures you can probably see that I also covered front entry with fiber reinforced perlite.
                  I then covered the rockwool with thin layer of ceramic tile glue. I did this because I would like to minimize water from vermicrite layer seeping into rockwool. I did not see anyone elso do that but I thought it made sense.
                  Here are some pictures:
ID:	305205Click image for larger version
                  Gorazd
                  • #54
                    First fire
                    After the insulation was on it was time for first fire.
                    I tried to keep flames low. Top of the dome peaked at 310C/590F and the floor at 220C/428F but that was for only short period of time. After about three hours I let the flame go out. With only embers the temps went down to 250C/482F on top and 190C/374f on the floor.
                    Flue was drawing well when the flames were high but there was some smoke when the flames were low. Flue temp was at max 90C/194F.
ID:	305207Click image for larger version
ID:	305208Click image for larger version
ID:	305210Click image for larger version
ID:	305211Click image for larger version
                    Gorazd
                    • #55
                      First goodies
                      With only embers left I tried some cooking/baking. I planned to bake cherry pie but I got hungry so I threw in also some chicken and potatoes. Embers cooled down so I was a bit sceptical but after an hour and 15 minutes I got the best chicken I ever tested. The pie was also very good even on top and bottom.
                      Whoau I got hungry again must go and east some more pie.
                      • #56
                        Re: Dome insulation
                        Something that has been recommended many times is using ceramic rigidizer or a Portland/acrylic slurry over insulation for just that purpose. Hope it worked out for you.
                        Old World Stone & Garden
                        John Ruskin
                        • #57
                          Thanks Stonecutter for your confirmation.
                          • #58
                            Pie!!!!!!!!!!!!!
                            [/CENTER]
                            • #59
                              Hi,
                              I finished my insulating layers. I added 2" of perlite concrete (fiber reinforced over 6mm steel rebar). Now i have a bit of dilema. Do I need concrete over that or would stucco be enough? My concern is snow or weight of it. (we can get max 1m or 3 feet)
                              • #60
                                Hi,
                                People have done it both ways. I would think the snow would break the stucco if it wasn't reinforced but I'm just guessing - wait for one of the other guys to weigh in.
                                [/CENTER]
