90cm (35-36 inch) Pompeii style oven in Slovenia - Forno Bravo Forum: The Wood-Fired Oven Community
  • 90cm (35-36 inch) Pompeii style oven in Slovenia
    Hello,
    im building a 90 cm (35-36inch) pompei style oven in Slovenia . Blueprints are from fornobravo.
    - base is from reinforcement concrete
    - insulation is termovermit (insulating concrete) 7cm (3inch) (insulating concrete)
    - row of firebrick for shape
    - sand 2 cm(1inch) for laying floor fire brick on it
    now im cuting a floor fire brick to shape
    So here are a pictures of progress.
    by
    Re: 90cm (35-36 inch) Pompeii style oven in Slovenia
    Looking good artman. Look forward to following your build. Only question is why the hole in the insulation material at the entry?
    Cheers ......... Steve
      Greenman - because i didnt have enough material. I didnt buy enought material.
      Today im going to lay down first row.
      by
        Well Artman - that has to be the best reason. I expect that it will not make much difference anyway. Still watching and once the first row is down the whole process seems to speed up after that.
        Hope it goes well for you.
          G'day
          Fancy piece of cutting of those firebricks at the front! That will let you get your hearth through in one flat plane.
            Nice start! Is it under an overhang or portico?
            My build documentary page:
              Nice job there...
              Sorry folks, but in our language: Kje dela? to peč? Za kaj jo bo? uporabljal? Lp
                Originally posted by artman View Post
                Hello,
                by
                Nice job there... Where exactly are you building this oven? I am from Slo too...
                  tibort - osrednja Slovenija , kaj bo? ti tudi gradil?
                  Uporabljal jo bom za pice, pečenke, kruh,.. kar se bo dalo not pripravit.
                  GarnerAc - (Is it under an overhang or portico?) under the external roof behind the house, summer kitchen.
                  Today progres!
                  by
                    Today progres!
                    by
                    Very clean looking build. Try to keep those vertical brick joints from lining up, stagger them as much as possible.
                      Today progres!
                      by
                      Ok, I am from the coast... I sent you a PM.
                        Artman can I ask you what did you put under your floor bricks. I can't find fireclay anywhere so I am thinking of using just quartz sand.
                        P.S. Gorenjska
                          gorazdr - lahko uporabi? kremenčev pesek tko delajo tud tapravi pečarji.Sej tko mam jaz, spodaj mam na betonski podlagi ulit Termovermit 7cm za izolacijo (zme?a? z cementom in vodo in ulije? podlago, poglej "http://www.strojansek-sp.si/vermit/slo/termovermit.htm", pol čez pa 1-2 cm peska oz. kremenčev pesek, nato pa ?amot. Lahko uporabi? kremenčev pesek tko delajo tud tapravi pečarji.
                          GarnerAC - thank you, i will try
                            I already poured insulation yesterday. 5" of Termovermit on top of 3" of aac blocks.
                            How long did you cure Termovermit?
                            Did you lay first course directly on vermiculite or do you have layer of sand below?
                            Some info for Slovene:
                            - Termovermit se dobi v Top domu (19.1?) vpra?ajte direktno za to ker ne vejo kaj je vermikulit.
                            - ?amotna opeka je 2.07? (top dom)
                            Katero malto uporablja?? Razmi?ljam da bi vzel Rofix 961 - do 1300 stopinj po 18.5?
                            Gorazd
                              Uf, ?koda ker nisi malo pobrskal po internetu...calsil board, ki ga po?ilja FB kupcem svojih peči najde? tudi pri nas. Ima bolj?o izolativno vrednost in se ne drobi. Pod talne plo?če se daje za izravnavo sol...to počnejo pečarji ki sem jih jaz videl pri delu in priznani Neapeljčani kot S. Ferrara na primer... Za vse informacije PM
