half brick igloo - Forno Bravo Forum: The Wood-Fired Oven Community
half brick igloo
  • half brick igloo
    hi all i am hoping to get some feeback here please i am hopping to enclose my 42 2 dome after insulating layer and vermiculite render with half brick to show off the dome feature like the jamie oliver one he has at his home my problem is would the brick be ok mortared on to the 3" vermiculite render or set off from the dome and loose filled any comment welcome
    link to my effort http://www.fornobravo.com/forum/f8/7...art-20707.html
    "95% reading this forum 5% building"
    Re: half brick igloo
    It is difficult to build the outer shell without something to lean the bricks against so the usual way is to make the vermicrete as lean as you can because more cement means poorer insulation. As the surface is not strong with weak vermicrete there is no point mortaring your bricks to it. If you could devise a way of easily building the outer shell free standing, then fill the space with loose vermiculite or perlite you would have the advantage of not having to dry that outer layer.
      Gudday
      I have bricked my dome. Over 1 to 2 ins of cement render and wire. Its quarter bricks mortared together so its really a dome itself and strong because of that.
      Gulfs dome is covered with brick purpose cut into tile thickness so would weight a lot less but would have no real strength as it would be to thin to gain strength from the dome shape.
      Davids is right in being cautious about the strength of just a v-Crete layer whichever way you go I'd add a layer of render for sure.
      Yes I've always admired Jamie Oliver's oven shame he copied mine.
        Someone, please point me in the direction of the "Jamie Oliver". I do agree with render over the vcrete. But, I strongly recomend an insulated/expansion joint between the fire brick of the dome and the vcrete. If, it is only one inch of ceramic fiber blanket (CFB), do include it. If the CFB, (or similar fluff insulation), is not included as an expansion joint, the render will crack . And what ever finish you place over the render will crack also. One other thing, don't forget the vent at the apex of the dome.
        Just Sayin'
        joe watson
        My Picasa Web Album
          Will be having a fb blanket around 3 inch which like you say will act as an expansion joint was also going give the dome 3 inch of vcrete and then brick outer was hoping to lay these on the vcrete to make life easy but after your comments I think I might have to build an inch or so off the vcrete and just fill void with loose vermiculite
            Gulf here is the Jamie oliver https://www.google.co.uk/search?q=ja...ml%3B720%3B630
              I will not be using the "squirrel style" vent though mine will come through entry arch as normal
                Some things are somewhat sacred and are better without celebrity. The ovens have been around for eons and the celebs come and go. Not everything is about the $$ and the B$
                Cheers ......... Steve
                  G'day
                  I bricked over a render layer because it was there! Which was great it gave me a guide. Can't use an IT as a guide. You have got to have something to build to.
                  I used a ply guide to build the dome, plenty of folk use insulated foam vanes and they will hold the dome up till completion. Can't see why a layer of pearlite cement wouldn't do the same.
                  The loose fill sounds alright but how do you plan to do it.?
                    Steve I'm just using his oven as example but he is a hero to me anyway got me cooking and done so much for kids dinners and general eating habbits of England than anyone to date he also has good taste in wfo's !!
                    Dave I was worried about bricking the outside up on the tender incase of movement which is why I was looking at a separate fill if I did I would proberly build as high as gravity would let me then use short holding stakes of the dome and just take time but I'm in no rush
                      Originally posted by leetheldc View Post
                      That is pretty oven, I especially like the chimney....but it's a shame to see it puking smoke all over the front opening. The oven opening is massive too, I'm sure that's not helping.
                      Old World Stone & Garden
                      John Ruskin
                        Yes I did notice that it does spoil it why it's that high I have no idea il keep mine lower but yes a lovely oven for a template
                          G'day
                          I don't have the smoke stains , luck or good management aside. I have a chimney opening witch is as wide as opening of my oven 18 inchs. That opens up to 20 inchs. A short stack means in the wrong conditions the wind might give you a face full but still no smoke stains on the front.
                            gulf what do mean about the vent on the dome apex please?
                              The "apex" is the uppermost point of the dome. I drew this cross section of what I did some time ago.
Name:	Insulation and Vent.jpg
                              I hope this helps. "Venting" is not a widely accepted practice. But, I would not build an igloo, without one
                              Several of the ovens in the Jamie Oliver's link do look great! I am just not sure which one you are referring to. If I weren't working 14 hour days , I am sure I could figure it out .
                              joe watson
                              My Picasa Web Album
