Dome insulation Help needed - Forno Bravo Forum: The Wood-Fired Oven Community
  • Dome insulation Help needed
    Need help here... How much perlite will I need for a 4 inch layer of insulation over my 42 inch oven dome. My math says around 2,2 cubic meters and that seems a bit too much?
    My build: http://www.fornobravo.com/forum/f8/4...way-19491.html
    Re: Dome insulation Help needed
    42" inside diameter + 4.5" brick thickness = 46.5" diameter to inside of insulation = 23.25" radius to inside of insulation +4" insulation = 27.25" radius to outside of insulation...
    (23.25)^3 * 3.14159 / 2 = 19,741 cu in oven volume
    (27.25)^3 * 3.14159 / 2 = 31,784 cu in volume to outside of insulation
    Difference is 12,043 cu in / 1728 (# cu in in cu ft) = 6.97 cu ft
    That should equal about 0.2 cu meters.
      Steellearning:
      I did the math this way:
      You have to subtract the volume of the dome without insulation from the volume of the insulated dome.
      I would suppose that 42 is the inner diameter, and the brick thickness is 4 inch. Thus:
      The UNINSULATED dome diameter is 42+4+4 = 50, r for uninsulated is: ru = 50/2 =25" = 0.635 m
      The insulated dome diameter is 50+4+4 = 58 (4" insulation is considered), r for insulated ri = 58/2 = 29" = 0.737 m
      Subtracting the volumes (We divide by 2 because domes are hemispheres):
      [3.14*4/3*(ri^3-ru^3)] / 2 = 0.3 cubic meters of perlite required.
      Please recheck my math for any mistakes.
      I forgot who said that.
        I did not check the math, but don't forget David's theory of 15% reduction in volume for V or P crete. I came up short on my floor insulation. So I did not make that mistake with my dome .
        joe watson
        My Picasa Web Album
          Gulf,
          You mean the insulation volume should be 15% the dome volume?
            Originally posted by v12spirit View Post
            Gulf,
            No. I mean the dry volume of vermiculite and cement is reduced by about 15% once you add water and mix it, creating a wet workable mix.
              Steellearning:
              Thanks v12spirit
              Looks like 2 x 200 ltr. bags of perlite will do the job.
