Yet another curing question - Forno Bravo Forum: The Wood-Fired Oven Community
  • Yet another curing question
    Ok, so my dome had been completed about 1 month ago and had been drying it with light bulbs in it.
    I cemented the flue yesterday and will be encasing it with bricks.
    The question is should I wait 1 week after I am done with any cementing around the flue before using charcoal or it is ok to start with charcoal in the dome while I still work around the flue?
    https://www.flickr.com/photos/yannic...7644224444113/
    Re: Yet another curing question
    Yannik,
    Much of the heat inside the dome will be exhausting through the flu you know causing the flu to get hot. If the cementing around the flu had some moisture it is likely to crack. I would go with waiting all the cement (even around the flu) to dry well before starting to cure.
    I forgot who said that.
      How long would you air dry things before the first small fire?
        The small amount of mortar you used to set the flue doesn't need a week to cure. Also, it's going to crack (a certainty) no matter how long you wait, because the dome is going to expand differently than the flue.
        Fire away and keep building.
        Old World Stone & Garden
        John Ruskin
          Originally posted by stonecutter View Post
          ................ Also, it's going to crack (a certainty) no matter how long you wait, because the dome is going to expand differently than the flue..............
          Another way to help legitimize a heatbreak,................is to think of it as an expansion joint .
          joe watson
          My Picasa Web Album
            In certain places it's not optional like a break between the vent and oven opening......like when the flue comes through the crown of the chimney.
            John Ruskin
              Maybe,..... not practical but, definately optional
              joe watson
              My Picasa Web Album
                Well, I guess everything is optional. What I mean is, not optional if you don't want a cracked flue (clay)...not stainless.
                John Ruskin
                  Not quite I separated my vent flute from the dome with heat break and insulation even though I wrapped it around the dome entry arch. Substantial difference in temperature still bloody got though.
                  Cheers Colin
                    It is optional in that with or without a break, the masonry isn't subjected to damaging expansion. Stopping heat from migrating into the vent masonry is optional, is not detrimental, and the performance gains are minimal.
                    John Ruskin
                      But, will improve "greatly" after all is dry .
                      joe watson
                      My Picasa Web Album
