First Course Of Brick
  • ColonelCorn76
    I have to go back & reset the Yahoo photo albums. When I posted them they were in the correct order to show our initial full soldier and then how that resulted in the wrong arch structure (actually more consistent with a Napoli style oven which would only be good for pizza vs. the Tuscan style that the Pompeii is when built with the first course set as 1/2 bricks). If you look at any of the end photos you'll see that the first arch is 1/2 bricks soldier style and then the rest are 1/2 bricks flat.
    Jim
  • Bob C
    Jim,
    Thank you.
    It does make sense...I wanted to be sure. Could not let all that labor go to waste.
    Bob C.
  • james
    Hi Bob,
    Jim and I did a trial layout with the first brick full height -- which did NOT work out. The sides were high and the dome curve too steep to go up without internal forms. I measured a couple of ovens here and looked at the dimensions of our refractory ovens, and Jim re-rolled the curve using a half brick and the more gentle curve. You cannot get the dome shape you want with the full high brick in the first course.
    Make sense?
  • Bob C
    started a topic First Course Of Brick
    I Am Finally At A Stage Where It Looks Like Something. Here Is My Question...
    On Jim's Photo Essay The First Course Looks Like A Full Soldier And On The Forno Site The First Course Looks To Be A Half Brick. Is There Any Critical Difference Between The Two?
    Thank You In Advance.
    Bob C
