Theremocouple,sand & fireclay? - Forno Bravo Forum: The Wood-Fired Oven Community
  • Theremocouple,sand & fireclay?
    Not sure how much sand and fireclay I should shop for for the paste needed for seting the firebricks on the hearth for the oven floor.
    Also not sure how the thermocouples will work. I have not seen one or really know exactly how they work. What do they look like (Physically how big etc)? Do they sit below the firebrick floor or right inside the oven? How many do I need and what be be the idea location? Planning on pouring the foundation and the stand walls and the stuctural hearth all in one pour this Friday. It will be an exposed agragate round 70" diameter stucture with a ring on top 4" high to hold the insulating pour to follow. I will try to post a picture after the forms are completed hopefully tommorow or day after....thanks in advance for this Wayne Bergman Canada
    see below for my oven album of progress to date
    http://picasaweb.google.com/wayneber...PizzaOvenWorld
    Re: Theremocouple,sand & fireclay?
    Hi Wayne,
    I know what it is like to over order. I purchased 5 x 25Kg bags of fireclay and used around 15Kg for the whole of my 40" Pompeii. That was used in the por man's mortar and for bedding the slightly narrower fire bricks into the heart, but I used it dry, not mixed with cement nor water.
    Hendo came and bought a bag but it is a bit too far to post one over to you.
    I have 4 thermocouples in my oven, on just under the cooking surface in the centre of the hearth, one on the underside of the hearth bricks, one around 15mm into the centre dome brick and the last measuring the temperature soak through the dome. There are different types but the K type that I used are made up of 2 different wire types which are fusion joined (welded) at their very tip. this joint of differing metals produce a very small electric current which is read on a sensitive meter and displayed in degrees Celcius or as the Americans use Fareheiht.
    See my link on:
    http://www.fornobravo.com/forum/6/th...es-1456-2.html
    permalink #13
    You won't need many, if any at all. I have more use for my Infra red thermometer that I aim into the oven for surface temp readings rather than the thermocouples. Once you get up and going, you will get to know your oven and temps and not use or rely on the thermocouple readings. The one thing that they do well, is to let you know how deep through the bricks, commonly known as 'soak', the temperature is so that you can establish how many cookings will be achievable at the time.
    Good luck with your pour.
    Neillís Pompeiii #1
    Neillís kitchen underway
      Thanks for this Neill....can you tell me more about the Infra red thermometer? How much do they cost and how would they work? Thanks....Wayne
        Hi Wayne,
        Forno Bravo have these infrared thermometers on line but as we don't have FB here in Australia, I purcheased mine from:
        http://www.maxtool.com/index/Digital...ermometers.asp
        I paid via Paypal anf the thermometer arrived within 6 days. Great sevice and a good product.
        Simply aim the laser pointer to where you want to read the remp, select the readout as ?C or ?F, press the trigger for 1 to 2 seconds and read the temperature. That easy and accurate to +or- 2?.The one I got is a MTPro and cost US$59.
        Do a Google search for 'Infrared thermometer' and find a supplier near you.
        Neillís Pompeiii #1
          You can find infared on the internet. I bought one for 41.00 and no shipping, works great
            Can you share with us a link to where you bought it? I'm starting to shop for one.
            Thanks!
            Ken H. - Kentucky
            42" Pompeii
              Thanks Dave!
              Ken H. - Kentucky
              42" Pompeii
                No problem.
                I am just sitting here bored as heck at work.
                Ughhhhh
                At least it's Friday~
                You might check out eBay, that Max tools website has the same gun but 10 bucks cheaper.
                Your dome is looking awesome. BTW
                My thread:
                My costs:
                My pics:
                  instrumart.com, it seems it went up a bit 49.00
