50" oven vent size - Forno Bravo Forum: The Wood-Fired Oven Community
50" oven vent size
  • 50" oven vent size
    Anyone know if an oven larger than 42" internal requires a larger vent? Mine is 50" internal. Just curious if I should go with an 8" vent as opposed to a 6"?
    Also, is there any product that can be laid out over the firebricks to make a smooth surface that will stand the heat and not crack or spall? I kind of doubt it as I haven't seen anyone doing this but thought I'd ask just in case (as I am at the floor stage now).
    As always any info. provided would be greatly appreciated. Thanks to all who post.
    Mongo
    Re: 50" oven vent size
    I'm using an eight inch square for a 36. I'd be concerned about a six inch vent on that big an oven. From the Pompeii plans:
    The following table outlines the internal diameter of the chimney for the different oven sizes:
    Oven Size Chimney Diameter
    32" - 36" - 8"
    40"+ - 10"
    I don't think there's a need for anything like this. Your firebrick floor should be smooth enough for any cooking need, and any high spot can be lapped off with a cut firebrick fragment. Do this sparingly: the factory "skin" is considerably harder than the inside of the bricks.
      Oh so you are saying I have to read the instructions now??? Missed that little chart. I still can't grasp though how the rectangular opening converts to an 8" internal pipe? In other words how big does my rectangle opening have to be for the vent - 6 x 10 inches will still do it? Then do these pipes come with adapters or will I have to build a concrete or steel adapter or? Damnit I'm a cook not a mason haha.
      You are right about the floor. The newbie in me was worried, but not that it's laid it doesn't catch on the peel at all so no problems there like you say.
      Thanks for the info.
        Considering that this is your restaurant oven...I assume...you might want to have a wider than 6 inches...8 inches should make pretty sure that no smoke gets beyond your outer opening. You should check some of dmun's posts...I think he made the throat for his oven cutting from two larger clay flue liners. There are a lot of options for stepping down to the 8 inch pipe.
        Best
        Dutch
