Iron Oven Dome! - Forno Bravo Forum: The Wood-Fired Oven Community
Iron Oven Dome!
  • Iron Oven Dome!
    Hi all,
    I was thinking of building an oven with a floor made from fire bricks and a dome made from metal!
    PLease i would like your input on this idea, what do you think?
    - Has anyone tried it before? Would it work?
    - Will i get the desierd heat for pizza cooking?
    - Will it heat faster, and retain heat?
    - How thick should the dome insulation layer be?
    - How thick should the metal be? is 5mm enough?
    - If you make pizza in a brick oven vs. a brick floor with a metal dome, will they both taste the same?
    - Do you need to insulate the vent? will that help retain heat in the oven, or it dosent matter?
    thanks,
    southpaw
    Re: Iron Oven Dome!
    I don't think the metal would retain enough heat.
    My thread:
    My costs:
    My pics:
