Re: Dave's WFO door
Copper would be cool! Nic work on the door, Dave.
I take it all your digits are still intact? No fingers lying in the dust.....
G.
Re: Dave's WFO door
Originally posted by Les View PostDave,
Did you run the screws for the handle all the way through the door? I was wandering how much heat would be conducted to the handle.
Actually I ran the screws through the front section only. Then I riveted the last piece into place. My only is concern is what I will do if the screws loosen up!
Anyways... it was my first one. I want to build another using copper for the front. Hopefully I can find some brass rivets to match.
Dave
Re: Dave's WFO door
Originally posted by Frances View PostLooks good Dave! Very nice! Wish mine were as nice...
It wasn't hard to do.
... I'm currently using a slab of insulating concrete, after my wood doors actually caught fire It works well, but looks UGLY.
Re: Dave's WFO door
Dave,
thanks,
Les...
Re: Dave's WFO door
Re: Dave's WFO door
Originally posted by dave d pizza lover View Postjust finished my door, made it out of a piece of soap stone . bolted a small stainless angle to the bottom to keep it verticle . also added a couple of stain less handles with wood over the handles for handling .this door is heavy but is easily slid out of the way and holds the heat very well
I would enjoy seeing some, if you do!
Dave
Re: Dave's WFO door
Re: Dave's WFO door
And a few more from last night.
I had a little time to work on it last night. Inside the house!
I've been thinking of covering one side with copper, and after I used one half as a door on Sunday, (it got colored from the smoke). I am definitely going to cover one side now!
Re: Dave's WFO door
I shall make great use of my band aid collection.
Quite extensive I might add!
Re: Dave's WFO door
Lots of sharp edges there Dave. Hope you're still wearing those gloves!
Interesting way of attacking the door issue. Look forward to seeing your progress. Remember to post pics of any fingers cut off along the way.
G.
