36" Pompeii low-dome in Livermore, CA
You are really moving along fast. Good idea to tackle the inside mortar before it sets up too hard.
Originally posted by UtahBeehiver View PostVery interesting build to watch, Not many low domes have been documented on the FB forum so this is nice to see.
Originally posted by RandyJ View PostVery cool build. It is amazing how many different ways there are to cut the bricks. Your jig is very cool. It looks way more user friendly than the brick shims that I used. Mine was useable but yours is repeatable. Great job. I look forward to seeing your next update.
Randy
I'm thinking it's safe to pull out the sand today? If there's any bad mortar on the inside faces of the bricks, I want to get it cleaned up before it gets too stiff.
- 1 like
Randy
After losing some sleep over brick cutting on Saturday night, I woke up and invented this 2-axis brick cutting jig. The only problem was that cutting 2 axis was too much for my hungover brain. After messing up a few cuts where one axis was tapered correctly and the other was opposite what it was supposed to be, I decided to give up on 2-axis tapering and tapered only one direction, to minimize the upside-down "v" on the side facing the inside of the oven.
Wow that is looking great. I was wondering how you were going to support that first course. That is very impressive looking. Keep up the great work.
Randy
Originally posted by JRPizza View PostLarry, nice steel work! Is that a kit or are you designing/welding it up custom? The steel hoop design is new to me - is it something that has been used before? I am curious how the oven will expand and contract with the different properties of the steel and brick.
I'm curious about heat expansion as well but it's a common method from what I can see with low-dome builds. I read a lot of conflicting info about expansion of steel and masonry, but I'm under the impression that they have similar properties which is why things like e.g. steel rebar can be used to reinforce masonry and concrete.
Originally posted by UtahBeehiver View PostNice start, be sure to cover the expansion gap between the first chain and the floor so mortar from the build does not fall into it, use some duct tape or stuff the cardboard spacers back in. Some have reported cracking to the dome because the expansion gap accidently filled up with mortar and the floor had no where to expand.
