Another aussie oven getting started - Forno Bravo Forum: The Wood-Fired Oven Community
  • Another aussie oven getting started
    More progress on my Pompeii:-
    To be sure I narrowed the centres for rebar to about 10 inches, and poured a 4 inch structural slab.
    I scored to perimeter of the slab, to bond the layer of concrete I will eventually pour as a border around insulation layer.
    The vermicrete was interesting. I tried the slurry mix method and it went too lumpy, so I reverted to the standard dry mix method, but reduced the ratio to about 8:1. I made a drill mixer to get it started, then finished mixing by hand.
    .......more to come
    Re: Another aussie oven getting started
    Hi agin,
    I know what you mean about the Vermiculite. I experienced a similar situation and ended up with I think from memory a 1:6 ratio.
    Seeee my information at :
    permalink #2 complete with [hotos.
    If you are building an igloo pompeii oven, you will experience even more problems with your insulation layers going over your themal blanlet.
    I had a few hickups until I found a solution which is here:
    permalink #10 where I added a little fire clay to make it stickier and easier to work, especiall rendering the bottom vetrtical areas.
    Neillís Pompeiii #1
    Neillís kitchen underway
