Background: My wife has a friend whose husband built a wood fired oven a few years ago. It is a Pompeii style and I think he followed the forno bravo plans. It has an exposed rendered dome. That is what my wife was expecting our wood fired oven to look like. We were discussing how I was going to finish it the other day. I was explaining how I was going to build an enclosure and explained the squirrel tail chimney and how the chimney would exit at the peak of a conical roof. She isn’t a fan of how tall the roof would need to be and was asking if I could make it shorter.
I’m going to build a round enclosure with a conical roof either way, but it did get me thinking about doing a more traditional vertical flue/chimney. I could then keep the roof closer to the dome of the oven. I figure that could reduce the height of the roof by at least 12”. I think this would also simplify the build a bit.
If I do a squirrel tail over the dome, my plan is to insulate between the dome and the chimney for better retained heat cooking. I was thinking of using P/V Crete to create a level surface between the flue and where the chimney will exit over the dome. Put down a layer of calcium silicate board (I bought an extra sheet for this purpose), then use a 8x12 clay flue liner.
So, what would the forno bravo community do? Vertical chimney or squirrel tail?
