I should be able to get the rebar for the hearth cut and wired in place this weekend, but probably won’t get it poured until next weekend. It will be 4” thick with 1/2” rebar ~10” on center.
I’m starting the hunt for calcium silicate board and firebricks. I’m in the south west corner of Rhode Island (I can see CT from the my house), if anyone has suggestions for places to acquire either please let me know! I tired a couple of local places thought might have calcium silicate board with no luck. It looks like there is a distribution international in Sharon MA, so I may need to just drive there or suck up the shipping cost and order online.
The local building supply place does carry firebrick. They are Whitacre Greer brand that from what I can tell are a light duty firebrick. I was hoping to find medium duty. What are people’s thoughts on building an oven with light duty bricks?
40” Pompeii in Rhode Island
Then I started building out the form for the hearth. I definitely didn’t make my life easy making this thing round. After scratching my head for a while I came up with a plan that I think will work. I built a table in the wood storage area and put a coupe of sheets of durock over that. The rest of the form is made from a sheet of plastic used for a wall covering in a bathroom or other wet space (the white plastic in the pictures) with a couple of sheets of hardboard as reinforcement.
I laid out where the oven floor will sit on the hearth and added pins to cast weep holes under the floor as well as around the edge of the dome where the blanket insulation will be. That should provide an exit path for any water trapped between the dome and the enclosure.
- Likes 2
The next step was the block work for the base. I used 8x8x8 CMUs so that the shape was a close to round as possible. I glued them together using PL500 on bond, then filled all of the cores with concrete and rebar. I also stuccoed the inside gave of the blocks before starting to form out the hearth since it will be much easier to access at this point. The plan is to have an arched entry to both the front and the back so I can have better access to the wood storage area.
I have been lurking on hear for a few years now reading through as many builds as I can. There is a lot of great information!
I have finally got to the point where I have most of my other projects around the house finished up and can start a wood fired oven build. I already built an outdoor kitchen on my back patio. When I designed and started that build I thought that using a portable wood fired oven (I bought an ooni karu) would be a good solution. Turns out my family really loves homemade pizza and a quickly grew frustrated with how small it is and the lack of heat retention. I started looking around for bigger alternatives and stumbled on this forum. I pretty quickly decided I need one of these in my life!
I love my outdoor kitchen and am not willing to tear it up to add a WFO, so I’m building one just behind it. It will be close enough to be able to use the counter for prep, but won’t be under the roof. The WFO is also too close to my property line to build a separate structure over it, so it will be exposed to the elements.
The plan is to build a Pompeii style oven with a 40” ID. It will be built on a round stand that will be clad with stone veneer to match my kitchen. I laid it out with the plan to build a round enclosure around it and a conical roof with slate shingles. I do really like the look of a dome and am considering a change to keep the igloo exposed. I am in an area that has winter with a lot of freeze/thaw cycles so I realize that isn’t ideal. Has anyone in a similar situation used a proper waterproofing solution over their dome (like flexcrete or thoroseal) and regretted not building an enclosure?
Here is my kitchen, the finishes on the WFO will be similar.
Tags: None
- Likes 1
