Coating the outside of the dome prior to insulation - Forno Bravo Forum: The Wood-Fired Oven Community
  • Coating the outside of the dome prior to insulation
    Quick Question. If my joint are all filled, do I need to put another coat of fireclay over the entire dome prior to the insulation blanket going on?
    Thanks.
    Thanks,
    GT
    For all pictures of oven build click address.http://picasaweb.google.com/ghtaylo/GeorgeTSPizzaOven
    Re: Coating the outside of the dome prior to insulation
    Have you brought it up to temp yet? I had a few minor cracks, so I went ahead and covered it up. If you develop some massive cracks, you may want the ability to fill them in.
    Les...
      It's not necessary. The blanket can go right on the brick. Depends on how much thermal mass you want in the dome.
      Picasa web album
      Oven-building thread
        I coated mine all over because I was sloppy about "backfilling" while I was building. So I used a bag to force it into the gaps, and then just slathered it on the outside to tidy it up a bit- I didn't have a saw that cut the whole way thru bricks, so I had a lot of broken ugly edges I didn't want to tear up my blanket with.
        It's all about the mass- I think you'll be ok if you've been better than I was about filling as you go.
        Elizabeth
          It's not required, but if you want more mass for cooking bread, or even cooking a brisket the following day(sometimes 2 days later) then go for it!
          It will increase your heat up times some, but probably not by more than 15-20 minutes.
          DAve
          My thread:
          My costs:
          My pics:
            Thanks everyone. I hope to complete the insulation tomorrow.
            Thanks,
            GT
