Removal of dome form work? - Forno Bravo Forum: The Wood-Fired Oven Community
  • Removal of dome form work?
    Hi. I completed my dome for my WFO on the weekend (I used a polystyrene from). How long should I wait before I remove the form??
    Jase
    Re: Removal of dome form work?
    Should be OK after a couple of days Jase. Hows it shaping up??
      Hi John.
      I pulled the from work out at lunch time and it didn't fall down (yet).
      Its starting to look good. Purchased stainless steel flu at lunch time. Oven entry arch looks good and will do the exterior arch once I have cleaned up a bit inside.
      Cant wait to start the curing phase.
      Jase
        Hi Jase,
        when I built my dome (and laid the hearth bricks) in 2 days I removed the bricks supporting the top dome courses immediately and then stood on top of it, yep 85kg on wet mortar/bricks.
        I did this also to enable me to clean the inside brick faces of surplus mortar when they were bedded onto the sand form.
        If it is ever going to collapse, then it was that moment.
        All domes if designed and built correctly are self supporting and should stay in place even without mortar or adhesive.
        Neillís Pompeiii #1
        Neillís kitchen underway
