How many fire bricks for a 32" oven? - Forno Bravo Forum: The Wood-Fired Oven Community
  • How many fire bricks for a 32" oven?
    Using a CAD program, I was able to determine an approximate number of 2.5 x 4.5 X 9 ("whole") firebricks needed to build the dome. This figure assumes approximately 6 firebricks used for the front opening; the rest of the opening and vent and chimney built using other materials.
    Assuming the dome is built of 4.5 X 4.5 X 2.5 bricks, you would need approximately 75 WHOLE bricks to build the oven.
    Assuming you want to get fancy, and cut trapezoids for the last 3 or 4 chains, the number of WHOLE bricks would be about 90.
    This does not include the floor, nor does it account for damage/waste, etc.
    It's just my estimate.
    Any thoughts?
    - Fio
    Bump - I answered my own question (Note how my current plan has again changed - I've decided to max out on space utilization and go for a 35" dome).
