dome built on top of or around oven floor?
  • #16
    Re: dome built on top of or around oven floor?
    The main thing is that the entire oven needs to be enveloped in insulation, except the mouth. I left the floor bricks stick out farther than necessary, and may have some heat leaks as a result.
    Doesn't have to be fussy, just cut off chunks you don't need.
