Matt's WFO Build
  • #31
    Re: Matt's WFO Build
    2. Don’t touch the mortar with your fingers. Your fingers are for picking your nose not moving mortar that is what the trowel is for.
    First off, that has got to be one of the funniest things I ever heard,,, God bless your father in law...
    2nd.. Your oven is looking great, your doing a fantastic job,,
    Mark
    • #32
      Wahoo I am getting very near the end. One more chain then the plug. I set the last chain using the TLAR method and it looks gray. Very excited.
      I enjoy cooking with wine, sometimes I even put it in the food I'm cooking. --- Julia Child
      http://picasaweb.google.com/mattluttropp
      • #33
        where's the pic's man ???
        • #34
          Okay sorry about not posting pictures the last time. I was in a hurry.
          Well we have been hard at work and are very close to closing the dome. Tomorrow I hope to set the keystone in the dome. It is definitely not going to be pretty but it will do the trick. As you can see from the pictures the interior of the dome leaves a little to be desired in terms of clean neat joints. I think I will take the angle grinder to some of the high spots to clean up the interior surface of the dome. Not sure how and when things got out of wack, but once it was it sort of continued to be a little off for the rest of the build.
          The keystone is going to be quite the carving project and I think I am going to use the same approach that Dino used in that I will set it in two pieces (lower and upper). This should make the shaping of the piece a lot easier.
          I think If I had to do this again I would spend more time on the lower chains making sure they were absolutely perfect as the errors seems to get amplified as you move up the dome. All in all I think the oven will work just fine, it just may not have the nicest interior in the forum. By the way I looked inside the commercially made oven at Tony Gemignani?s restaurant in San Francisco and I could see mortar smears and other imperfections in it, so I am going to assume that this is all an exercise in esthetics.
          By the way the kids wanted to help with the oven so I asked them to cover the ugly outside of the dome with a thin layer of mortar. They thought this was a great idea as it was just like playing in the mud but with mortar mix. Yes they had gloves on and it was the home brew stuff so it is not an extravagant expense. Besides I think a nice smooth coat on the outside will help me identify cracks that open up when I cure the oven.
          Since I used a lot of the home brew mortar I am planning on waiting 28 days before I start the curing process so that the mortar has a chance to reach the majority of its strength before I drive all the moisture out of it. I suspect this will help a great deal with potential cracking issues. I noticed that quite a few of the folks from England and Australia have used propane burners and charcoal to cure their ovens. They seem to like the idea of starting at a lower temperature and holding it for a while then slowly raising the temperatures without a cool off period. Has anyone else tried this approach with good results? At the very least I am thinking of using propane for the lower temp fires as it seems to be rather convenient.
          • #35
            I think it looks great,, Hope you get your dome closed,, Then the hard part,,,,28 days waiting......
            Mark
            • #36
              Well we did it. The dome is complete. The keystone may not be the standard configuration but it will work. Once the oven cures I will crawl inside with a grinder and clean up some of the lips and mortar spills that will drive me crazy if I just leave them. I definitely plan on using a full on respirator and face shield for that job. Should be interesting.
              I have attached the mandatory Hansel and Gretel type photos for the kids in the oven as well as the full build team.
              Now I just have to start thinking about how to build the gabled house type enclosure and more importantly how in the world you get a flue pipe through the top of a roof at the peak. Dino did it with a custom build copper flashing system. Is there a standard off the shelf version in steel available or do you have to have this flashing custom built? Any help would be appreciated.
              • #37
                I cant see any of the spills from here in New Jersey,,, and there even harder to see when theres a fire going....
                • #38
                  I agree. I was annoyed with some of the mortar on the inside of my oven. When the oven's cold, the black covers the problems up. When the oven is hot, you can't stick your head in to see the problems.
                  Joe
                  Joe
                  • #39
                    Matt,
                    Good work.
                    I went over to Tony's Pizzeria last Friday and sat at the table looking into his dome oven. And you're right. I'd estimate his mortar joints are all 3/8" to 1/2" wide on each side of the bricks on the inside of the oven. The last last time I went Tony sat down and was telling us that he had this oven built in Italy and shipped over on the stand and the only thing they did here was apply that cracked tile finish. Long story short, like everyone is saying, "Perfect the food, not the dome." There are an incredible number of artisans on this site, but what would you expect from people who are willing to tackle something like this.
                    RE: custom sheet metal flashing. My friend has a sheet metal shop, but its here in Burlingame. Based on a sketch and dimensions, they can build anything to order. They can do stuff out of copper sheet, galvanized sheet metal, and stainless and in lots of different thicknesses. Depending on how complex your flashing is going to be, I'd imagine most sheet metal shops will be able to cut and bend something for you. Most of their shop work is for other contractors/installers because they're set up to fabricate faster. His shop is Burlingame Heating. If you don't find anything in your neck of the woods. I can certainly give you his contact info.
                    Congrats again on closing it up before this big storm hits.
                    -wayne
                    ps. If you haven't already, you've got to go to Pizzeria Picco in Larkspur. Just as good or even better than Tony's.
                    • #40
                      Mark and Joe, thanks for the words of encouragement on not messing with the cleanup. I may take your advice as I am 6'2" and crawling in the oven does not leave a lot of room to work.
                      Wayne, thanks for the sheet metal flashing help. I will see what I can find here, if I strike out I will contact you regarding your friends business.
                      I have not been to Larkspur in a very long time, next time I get there I will definately have a pizza at Pizzeria Picco.
                      • #41
                        My version of sketchup .... called mockup.
                        • #42
                          Wow, so photorealistic. j/k
                          • #43
                            Congratulations Matt!
                            How did you back into the dome? No...wait . Don't answer that. My knees and back are already aching. Great shot of the whole family of helpers. The keystone plug and mortar joints are beyond OK or serviceable. They are an artisans work of art that. I've had brick layers and other construction types look in awe at my oven because they know the kind of craftsmanship that goes in it and yours is no different.
                            RE: the flu pipe. If you want the round pipe to go straight out the top peak, you need to have flashing made like mine. BUT, don't use copper like I did. Have it made of galv. metal or else you run into having to use copper nails or somehow avoid the steel stud framing unless your roof joist will be wood.
                            RE: the flu pipe: Mike (mfiore) went out the top peak but built a square frame around the round pipe. Now you can use standard edge flashing you buy at Lowes or HD. You can brick it or paint it.
                            RE: flu pipe: Last choice is to buy 2 (two) 45 deg bends from the various duratech vent pipe distributors online but they are expensive, however that will put the round vent out the side of your roof gable and not dead center which is easier to flash with off the shelf collars for slopped roofs.
                            Nice sketchup work too! Cheers, Dino
                            My Oven Costs Spreadsheet
                            My Oven Thread
                            • #44
                              Thanks for the kind words Dino. I definitely have an enhanced appreciation for the skill and patience an oven like yours takes to build. I agree mine will be serviceable and is nice. But you built yourself a Porsche 911 and I built myself a Volkswagen Karmengia. They are both cool looking but one is definitely not equal to the other.
                              I think I will be going to custom flashing route as I just could not stand the look of an offset flue out the roof. This project has taken too long and cost too much money to have something look not quite right. I definitely will go the galvanized steel route or equivalent.
                              I have been thinking more about the enclosure and I will be using metal studs. In the San Francisco Bay area these things are extremely hard to find. I am envious of all of you that have a Lowes or HD that carries this stuff. That said everything I have read so far says that these are not for load bearing walls. Obviously all of my walls will be load bearing, but not by house standards. What is the minimum gauge and spacing that all of you have used with success? I was thinking of 18” OC for the studs and the trusses.
                              • #45
                                I used 20 guage. These walls are not really load bearing. They just hold the hardibacker and the roof up. As long as you keep the studs vertical, they will bear what you need them to bear. I found the metal studs at a lumber yard. HD was always out and Lowes doesn't carry them in Utah. A lot of commercial construction uses metal studs, so I would be really surprised if you can't find them at a regular lumber yard. When you plan the spacing, consider the dimensions of what you will attach to them. Hardibacker comes in 3x5 sheets. If you put them on horizontally, 15 inch centers work well (adding to 60 inches); vertically 18 works. I ended up adding studs in a couple of places to make the hardibacker seams fit a stud.
                                Joe
                                Joe
