arches question - Forno Bravo Forum: The Wood-Fired Oven Community
arches question
  • arches question
    Should one make the outside arch slightly bigger than the inside arch.
    Re: arches question
    That's what I did. You want a reveal on the inside arch to fit a door against. If the outer arch is not slightly larger, the door will fit to tightly before you can fit it up against the inner arch.
    Joe
      Re: arches question
      Yes, each of my arches was about 1 inch wider.
      This helps you have two doors one door for the inner arch and one for the outer arch to keep out the elements.
      Hope this helps.
      Dick
