flue questions - Forno Bravo Forum: The Wood-Fired Oven Community
flue questions
  • flue questions
    I built a pompeii oven with a 48 inch interior diameter using the FB plans. I'm venting with clay pipe from the mouth of the oven to the top of the dome. I need to run the flue up 2 floors. Any recommendations on what diameter flue and clay pipe I need?
    Sincerely,
    Buix5
    Re: flue questions
    Hey Buix5, have you had a look at Dmun's build:
    http://www.fornobravo.com/forum/f9/d...t-ii-1876.html
    It's a smaller oven, but has a tall chimney like you describe, also a meticulously documented build. Lots of good info.
    Doug
      Re: flue questions
      I have a 40" Pompeii with an 8" round steel flue 10' high and it draws a treat with absolutely no smoke out the front arch.
      I would play it safe and run either an 8" square or preferable 10" round stainless flue if I was to install one.
      Cheers.
      Rastys
      If you don't succeed the first time, try again and again until you get it right!
