Ugly Mortar Joints - Forno Bravo Forum: The Wood-Fired Oven Community
Ugly Mortar Joints
  • Ugly Mortar Joints
    post to hopefully gain some comfort from the 'Masters' I see on this forum.....
    I am on my 6th course and no matter my efforts my mortar joints look they were done by a spastic 3'rd grader. You know it's a bad sign when the OUTSIDE of the chain looks better than the INSIDE ! None of the chain to chain joints are over 1/2" at the backside so I think I am fine structurally. I just can't seem to get the knack of getting each chain brick in 'square' and 'faced' properly with several ending up a bit cock-eyed. The mortar joints inside the oven are generally tight and small, just some at angles including the dreaded triangle between adjoining chain brick. Looking a Les's Oven makes me sick!
    Please tell the the Pizza will not know the difference!
    Re: Ugly Mortar Joints
    RDWHAHB. Oops. Wrong forum. Relax, don't worry, have a pizza. It'll be fine.
      You should try my cooking It's going to work just fine. One trick to keep people from looking at your work is to keep a hot fire going.
      Les...
        I don't trust my brick laying skills so I intend to use a brick guide.
        George
        My 34" WFO build
          If the choice is perfecting mortar or pizza, go for pizza. Your friends only care about the pizza anyway.
          [/CENTER]
            I agree 100%.... as long as it cooks your golden
              I have also created some "challenged" looking brick placements inside my oven. Some of them offended me to the point that I took an angle grinder to them clean them up. Now they look a bit better. I agree with the group. Don’t worry too much about it, after all people are going to be more interested in the pizza.
              For what it is worth I saw a professionally made oven in a restaurant this weekend and the mortar joints were huge and I thought rather sloppy. Pizzas that came out of the oven were fantastic, so clearly it works.
              I enjoy cooking with wine, sometimes I even put it in the food I'm cooking. --- Julia Child
              http://picasaweb.google.com/mattluttropp
