I don't understand why you would want to wave the insulation. I know if all you want to cook are pies, this would suffice. But down the road, if you wanted to cook a roast or turkey, wouldn't you want to retain the heat? The only downside to cladding your dome is the fact we can't see your awesome tile cutting abilities. Am I missing something?
Yes, what I'm not doing is adding a layer of refractory material to the outside of the dome to add mass. Remember that my dome is only 2 1/4 thick, which is thin by pompeii standards. I'm enclosing the dome and insulating as much as possible, I'm even saving the old fiberglass I'm taking out of the internal walls to pile on top of the vermiculite. I'm also considering using a layer of foam below the main slab, just to keep things toasty.
I'm a great believer in insulation, not excess thermal mass.
This is a very cool approach (pun intended) - but I don't understand why you would want to wave the insulation. I know if all you want to cook are pies, this would suffice. But down the road, if you wanted to cook a roast or turkey, wouldn't you want to retain the heat? The only downside to cladding your dome is the fact we can't see your awesome tile cutting abilities. Am I missing something?
Yes, everything will be mortared with Heat-Stop. I want this thing to be so strong you could jump up and down on top of it, not that I would. My vision is a solid unit floating on the fireclay base that would handle linear expansion without cracking. I want a non-mortared joint between the entryway and the decorative front arch, for the same reason
I'm not cladding the outside. I have been thinking for months that you don't need any more thermal mass that is in a modular oven, or 2". It would be different if I was planning to make pizzas all day, but I want this to be a quick and efficient heat oven.
I don't know how I'm handling the top of the entry. I may spring for a couple of refractory lintels if I'm feeling flush, or I may piece an arch together out of all my brick scraps. One thing for sure, there aren't going to be any exposed angle irons over my door.
One final thing about Heat-Stop. It's made for really thin joints, from 1/16 to 1/8 in thickness. My one question was whether it was strong enough to hold the triangles together during the second two angle cuts. I'll know soon.
The brick thickness on this oven should allow for faster heat up times than most of the ovens I've seen that use 1/2 bricks to make the dome. An obvious result of this - it takes fewer total bricks to make the dome.
A couple questions:
Will you use mortar between the pieces or coat the outer layer?
How thick do you intend to make the cladding? I was thinking that a dry fit with cladding would allow for some movement during final fit.
I'm wondering how you plan to assemble this. Actually having a lot of fun thinking about it. I'm envisioning taking the brick pieces and shaping them in to the hexagons and pentagons by gluing their faces with wall paper paste and heavy paper - the paper and organic paste would burn off in the first firing. I guess that could be done with mortar between the joints as well. If the inner and outer faces were papererd - they would hold their shape easily during handling. (hmm - modular - just like geodesic domes were intended to be - there I go mr. MOTO again)
How will you support the dome over the opening? Looks like you've got a cast entryway in mind.
The add on's to the bricks are not cut at an angle to the other brick. If this joint breaks, with the 6 1/2 degree angle be enough to hold them in?
I guess this is what I was getting to when I asked if you were going to mortar between the triangles - if so the mortar between bricks could errode and allow for some movement.
Never mind, just pulled out my calculator, a 6.5 degree angle is rather significant over 2.5 to 3 inches or so.- Even if the little pieces crumbled or somehow fell out the major brick piece would remain in place. (Moto strikes again) I just like this better and better.
I'm sure you have though of this -- what will the impact of thermal expansion and contraction be on the various pieces and mortars, along with the pull of gravity? I have to imagine that they will move in harmony, and that the geodesic dome will stand forever.
I think the refractory cement is closely matched to the expansion of the firebrick. A couple of years ago i put a Rumford fireplace into the opening of an old coal grate in my house, using the same materials. I've not had so much as a hairline crack, although it's not subjected to the same extremes of heat.
As for geodesic domes, they are hugely strong. The place that has the dome calculator uses them to make pavilions for things like Burning Man. They are made out of half inch conduit, and you know how flimsy that stuff is. They crimp and bend the ends, and bolt them together, and multiple people can climb on the frame.
David,
This is so cool, I'm at a loss for words -- so I will use the highly articulate "wow." We are all going to be engrossed watching your progess and seeing your "dome" come to fruition.
This will be the Swiss Clock of Italian Pizza ovens.
The bricks, which are standard grade firebricks, in "red" (really sort of a reddish brown) from Progressive Brick, in Hasbrouck Heights NJ. That's a 45 minute drive from me, but i really like the darker firebrick. They were .70 usd per brick when I bought 150. I also picked up a 50 lb bag of Heat_Stop, for fifty bucks.
The bricks cut with amazing ease. The Chinese saw worked like a champ, blasting through the firebricks quickly, easily and accurately.
I started by cutting the bottom edge angle for every full triangle, and then cutting the pointy tops of the "6" triangles. This left almost enough ends to make the tops of the "5" triangles. I cut one corner off a bottom brick to get the right number.
I then mixed up a little Heat-stop to the consistancy of peanut butter, and spread it on the uncut edge of the triangles. I put them in position, and scraped off the excess. Later today when they dry more, I'll scrub the visible face with water and a brush.
Back before the east coast was under water, I started digging the footings for my oven. Since this will be part of an existing structure, and support a two-story masonry chimney, it needs full footings below the frost line. Here's a picture of the dig:
As soon as the mud puddle at the bottom of my three foot rectangular hole dries out, I'll be back to pouring footings, but in the meantime:
This post marks the start of the construction of my pompeii inspired oven. There has been a lot of discussion about how the bricks could be cut so that they fit evenly,without mounds of mortar. This usually involves the idea of three dimentional trapezoids, which are different on every level. My idea is to create an oven using the form of a geodesic dome. Anyone who has seen a soccer ball is familiar with the idea:
It's hexagons alternating with pentagons. Geodesic domes are constructed from triangles, and the pentagons are made of five triangles, and the hexagons from six triangles. What size to make the triangles? Here's a handy web-based dome calculator from Desert Domes.
But, but, but, (I hear you say), fire bricks are rectangles and you need triangles, and triangles with 6 1/2 degree tapered edges! This is crazy!
That's it exactly. I am crazy, and I'm not advocating that anyone else do this. If you want a perfect fit oven, buy one of James' modular ovens. As I explained to a friend the other night: You've heard of labor-saving appliances? Well a wood-fired brick oven is a labor-consuming appliance.
