dmun's 36" geodesic oven
That is a nice solution. Be careful as an uninsulated flue like that will certainly crack if not insulated. Instead of applying a layer on the inside it would be better to apply a layer on the outside. If it were mine I’d be using a 7:1 vermicrete mix an inch or more thick (you can adjust this as you wish in the knowledge that the most vulnerable part is that closest to the fire). Then when it is pretty dry you can render over it with a standard cement render mix and fashion some sort of weather cap.
Originally posted by dmun View Postflue funnel
Once on this forum, I saw a picture that someone posted of two flue tiles side by side sitting on top of the oven opening. They may just have had them stored there, but it gave me an idea:
If you cut an 8 x 12 flue tile on the bias, as drawn, you get,
Two pieces like this, which,
can be trimmed like this,
and assembled into a thing like this. It fits an 8 x 8 flue tile on top, and flares to 8 x 15 1/2 on the bottom. Cool, huh? Stay away from those pricy sheet metal fabricators. Warning, refractory flue tile is the hardest thing I've cut so far on this project, and the size of the thing means that the long cuts need to be made with a diamond blade in the angle grinder.
Thanks. I have hit a serious delay on this part!
Re: Here's a flashback to before the rains
Originally posted by dmun View PostBack before the east coast was under water, I started digging the footings for my oven. Since this will be part of an existing structure, and support a two-story masonry chimney, it needs full footings below the frost line. Here's a picture of the dig:
As soon as the mud puddle at the bottom of my three foot rectangular hole dries out, I'll be back to pouring footings, but in the meantime:
Re: dmun's 36" geodesic oven
Very interesting photos! I like your covering with stone.
I will eventually get to mine - as mentioned I will be making it much thicker. My first attempt was to mix two different types of cement in the mold at one time - the inside refractory layer then the outside would be more of an insulating layer. I would have seams completely through the dome then. Your idea gets rid of that, I like it.
More to come when time permits!
Originally posted by dmun View PostYour point is well taken. It happens that the points on the ends of the triangles have not deteriorated at all: all the cracking was between the preassembled polygons.
The key fault with my design was it's thinness. If you could make a geodesic oven with the standard 4 1/2 inch thickness, I'm sure it would be much more stable.
One problem is that the refractory cement is becoming brittle (chalky) on the surface. If you rub your finger over the surface it rubs of like dust.
Therefore, I too may be in for a rebuild at some time in the not too far away future.
Anyway, if anyone is interested in seeing some of the build photo's they are at the link below.
Wood Fired Oven Plans
Doesn't look like edschmidt has visited the forum in awhile...
I'm a newbie looking to build my first WFO and am really interested in this design too.
edschmidt,
Do you have the 2 form deminsions?
edschmidt,
I read where you built your oven in april of 2007. Have you had any problems with your design? I am going to start my oven project and it looks to me like you have the best design. There are a couple of question about the construction that I am unclear on. I would like to make mine in the igloo style, no enclosure.Was the slip layer a piece of paper that was put down on the dome than concrete was appied over the paper? Next the 4" of concrete was it regular portland type with wire mesh for reinforcement? Im worried about leaving it concrete on the outside. I like the rustic look but I think I will have a moisture problem with it being outside in the elements. it does not freeze here. Did the concrete get hot when firing? if not then maybe a coat of paint would do for waterproofing.
That sounds really cool!
Any pics??
I cast mine from 2 triangle molds. If your using a castable refractory there wouldnt be shrinkage to compensate for. If you are making it from clay obviously there would be shrinkage from the clay drying. The reason I used the triangles to make the pentagons and hexagons was I thought the smaller pieces would be less likely to experience a heat differential within the piece. Also I tapered mine so that I could build without mortar to further isolate each piece from heat differential and cracking. I also did make some newer molds from silicone with the domed interior which you are talking about and it does make for a beautiful finish inside.
This thread is fantastic.
I am a dome guy and a WFO enthusiast... goes great together!
I m thinking if you make the dome (freq 3, as you have) out of just hexagons and pentagons, you could potentially make an entire dome from only 4 molds. Make it 20% larger - for shrinkage, and if the shrinkage varies so what? All parts will shrink the same!
Anothe feature would to create a spherical surface on the inside of the polygons. Then when built, the dome would have a specific focus and not a series of planes like a dome.
The only thing that would be of concern to me would be the fine points of the cuts.In firework we never have any cuts to small or fine to a sharp point as they can be very suseptable to thermal shock and crumbling or breaking off.
Originally posted by bricks View PostHi dmum
I have just viewed your dome and think that the design plans are great.The only thing that would be of concern to me would be the fine points of the cuts.In firework we never have any cuts to small or fine to a sharp point as they can be very suseptable to thermal shock and crumbling or breaking off.Eg when building over an arch instead of having a pointed cut we turn the brick on edge and mark/cut.Last edited by brickie in oz; 03-12-2011, 10:47 PM.
