Firebrick Hearth Uneven - Forno Bravo Forum: The Wood-Fired Oven Community
  • Firebrick Hearth Uneven
    Hi folks. It's been a while since I have posted on the site. My oven was completed last summer. It's been over a year now of enjoyment with pizza's and breads.
    I noticed the other day when I fired it up that some (2) of the bricks just inside the entry way and to the left are not even. My rake and peel catch the edge. I do not remember this being the case when I built it. So my suspicion is that this has developed over the last year or so. I am built on the fibre board (2" thick as I recall).
    Is it possible the fibre board has compressed and has caused this to happen?
    Post #14 in my thread shows the picture:
    http://www.fornobravo.com/forum/8/to...ld-4678-2.html
    Should I worry about this?
    Check out my build at:
    http://www.fornobravo.com/forum/f8/t...uild-4678.html
    Re: Firebrick Hearth Uneven
    "My rake and peel catch the edge."
    If you have an angle grider, just trim the edges back a bit.
    "Should I worry about this?"
    Not unless there is some sort of structural failure (examine your suspended slab closely for cracking.)
