advice on insulation, door and chimney pipe wanted - Forno Bravo Forum: The Wood-Fired Oven Community
  • advice on insulation, door and chimney pipe wanted
    Well, I am ready to order the insulation for my oven. But I need advice. I am not sure that I want to "house" the oven, you know, with framework and bricks or siding. I think I just want it to be dome shaped.
    I think I want to stucco it - is that advisable in north eastern Kansas?
    I would actually like to do some mosaic work on it.
    How much insulation - should I do part blanket? all Blanket? All vermiculite, part vermiculite?
    How about the door? What's the best way to get a door? Materials? wood? Metal? insulation?
    And the chimney? It just seems that it's awful expensive to order the chimney pipe from forno bravo...but what's the best thing to do?
    Thanks for answering these questions that I know are in this forum somewhere, but I just don't want to take the time to look!
    ha ha
    Cecelia
    Re: advice on insulation, door and chimney pipe wanted
    Cecilia,
    It all depends on what your chimney is made from and what you want it to look like finished!
    If it is a steel flue, you could put some superwool blanket around it and sheath a larger stainless or decorative cover over it, wrap it in chicken wire and plaster it with vermiculite cement (BUT then you will have to waterproof it as it will deteriorate with moisture).
    If it is brick, then you won't have to insulate it at all.
    There are many postings/threads on doors so do a search
    This is the best way as you will see the range of previous responses rather than the few who might take the time to repeat again, their information!
    Don't skimp on the final finishing touches. You have come so far and it would be a pity to spoil it all for say $50 to $100! Always look for alternatives but then you often have to compromise.
    Neillís Pompeiii #1
    Neillís kitchen underway
      You are right, Neill - I should take the time to browse.
      I will, I promise.
      Thanks,
      Cecelia
