High Heat adhesive? - Forno Bravo Forum: The Wood-Fired Oven Community
Hello,
See more
See less
High Heat adhesive?
  • High Heat adhesive?
    Does anyone know of a high heat adhesive that I could use to construct my door? It will be made out of a jigsaw puzzle of insulating firebrick.
    Derk
    Re: High Heat adhesive?
    Pure silicone is good to around 500 degrees. Things like J-B weld maybe?
      Tom,
      About what temperature are you at when you lock up your oven for a overnight slow cook?
      Less than 500 F?
        Way down there around 250 max to start, but I put the door on after the last pizza is done, above 800 degrees.
          You can try it, but I think that an adhesive solution may be hard to achieve. There is a lot of expansion/contraction involved. I would try for some sort of mechanical solution.
