Oven door is gone! - Forno Bravo Forum: The Wood-Fired Oven Community
Hello,
See more
See less
Oven door is gone!
  • Oven door is gone!
    I stack bricks in the oven opening and then I place a three plywood thick door over the opening. It has worked very for well except this morning, all that is left is ashes and the bricks. Any thoughts on a insulating door design.
    Re: Oven door is gone!
    R.I.P. Doc Opa's oven door...
    I built an aluminum box with 2" of insulating blanket in it and a long stem thermometer stuck through it. Simple, light, and insulates well.
    George
    My 34" WFO build
      Where did it go?
        Yep. Been there, done that!
        I got up the next morning and looked out and noticed the door missing. I was thinking "I'm sure that I put that door on last night" It wasn't until I noticed the pile of ashes that I figured out what had happened.
        I'm still on my 2nd temporary door which is just a bit of 12mm plywood fixed onto an aerated concrete block. One day I'll get around to making a permanent door.
        Paul
          I caught mine just in time - was about to load the oven up with bread when I saw smoke pouring off the door. It's a little charred but still quite solid.
          My Clay Oven build:
          http://www.fornobravo.com/forum/f43/...dah-12821.html
            I thought man, that smells like burning cedar...and yep, it was my door!
            Only charred the inside, but would have lost it completely if I was away a few more minutes. Working on a permanent insulated door soon...if I ever get to it...
            Ernie
            Ducane 5 Burner Stainless / 34 Inch WFO
              fxpose - what thickness Alu that is? Did you notice any heat damage on it?
              my own Quest for Fire:
              http://www.flickr.com/photos/leckig/
                No heat damage yet, but I expect it to eventually crack or tear. If it does, I can easily replace the inner alu face with 22 ga sheet metal.
                The sheet aluminum came from a couple of large alu food serving trays which I had laying around. The alu was soft and pliable so it was very easy to cut and bend to shape.
                George
                My 34" WFO build
                  so looks like you think 22 ga metal may work better? Did you put any frame inside that box? I need to make door this weekend, I really like your concept!
                    No, absolutely no framing. I originally thought about framing because the alu felt so flimsy but after I started bending and riveting the sections together it became very rigid.
                    George
                    My 34" WFO build
                      awesome! Time to buy a riveter
