The reverse build.
  • #16
    Re: The reverse build.
    Include a thermal break between the inner and outer arch if you want to improve heat retention.
    • #17
      David, would you mind defining a 'thermal break'?
      I'm thinking about inserting about 5 or 6 insulated firebricks from right to left on the oven landing just outside the first oven arch....Is that what you mean?
      Lee B.
      DFW area, Texas, USA
      • #18
        Ive already thought of doing that, is ceramic blanket good sandwiched in between?
        • #19
          Yeah, I use only 10mm vermicrete, but it is way better than direct contact.Apart from reducing heat conduction=heat loss, it also provides space for thermal expansion of the inner parts of the oven which avoids pressure on the outer arch.
          • #20
            I had provided for expansion all around on the last oven, Ive seen what can happen to brickwork from the effects of the sun never mind a furnace..
            Its not my work btw.
