Home made pizza cutter. - Forno Bravo Forum: The Wood-Fired Oven Community
Hello,
See more
See less
  • Home made pizza cutter.
    Here is a pizza cutter I made out of Huon Pine and stainless steel, two of the most enduring materials you can get.
    Its fairly simple, cut a slot in the timber to take the stainless cutter blade.
    Use a durable timber as it has to be washed.
    Also make sure the blade has a slight bend in it to keep it secure in the timber slot.
    Re: Home made pizza cutter.
    These are the best cutters IMO. I just bent the sheet around twice for the handle. It's easier if you have access to a bender. What thickness SS did you use? I used .55mm and I think it's a bit too thin.
      I think it was 1mm, its been a while since I made them all..
      Ive given most of them away to guests of my pizza parties..
