Oven Door - Forno Bravo Forum: The Wood-Fired Oven Community
Hello,
See more
See less
Oven Door
  • Oven Door
    Hi All,
    I've fired up my oven a few times now and when its cold the wooden template i used to do my arches cover the entrance pretty well.
    However a few hours later when it gets hotter some part of my entrance moves the the wooden template doesn't fit as snug anymore.
    Does anyone else have this issue and if so how did you make your oven door (to fit both when cold and hot???
    I've heard of bricks moving but not the entrance expanding .....
    When things get cold, it all goes back to norm.
    Any theories, comments??
    Cheers,
    Gummz
    Re: Oven Door
    HI Gummz,
    my oven has a steel door surround and arch lintel, so there is not much movement. My door is made to go up against a vertical seal rather than fit snugly within the door opening void. A picture of your oven entrance would help solve or reduce your problem.
    Neillís Pompeiii #1
    Neillís kitchen underway
      Re: Oven Door
      Masonry and wood do have very different thermal coefficients of expansions, but I wouldn't think it would be visible. Very interesting.
      Hmm. I just pulled up the data:
      Coefficients of Linear Expansion
      It's not that big a difference.
      Hmm.
        Re: Oven Door
        I experienced the same effect with my first oven. I made a tapered wooden door which I cast over with cartable refractory so the fit was pretty tight. If I left the door in place overnight it was difficult to remove because the refractory had expanded significantly on heating and then shrunk tight around it on cooling. I learnt to pull the door out a tiny bit before leaving it overnight. I think the door is better if it sits in front of the arch rather than in it for the above reason.
