Custom door - Forno Bravo Forum: The Wood-Fired Oven Community
Hello,
See more
See less
Custom door
  • Custom door
    I m building a 40 inch oven I want to build a door that slides up and down in built in tracks how thick of steal should I use thanks Jason
    Re: Custom door
    Sounds like an innovative design, but really.. sounds like a really difficult setup.. is it worth the time invested?
    In the end, the choice is yours, but i can't see how this would work easily.
      Re: Custom door
      i was thinking the same as i have a 30mm lump of iron from a digger .that is lovely and flat .. then i thought if it slips out of what is holding it up . it now becomes guillotine . so maybe something tin ish. with a lip on it . so not to chop off some bits .. or if you leave it sharp you could chop your pizza with it . by dropping it on it a couple of times.,,
        Re: Custom door
        Here is one built by Dolf
        http://www.fornobravo.com/forum/21/d...tml#post114344
