pizza spinner - Forno Bravo Forum: The Wood-Fired Oven Community
Hello,
See more
See less
pizza spinner
  • pizza spinner
    This unit comes in handy for spinning pizza's while working the oven. 1/4" Aluminum round welded into 1/2" Aluminum round and then inset into a spring handle. The tip is an Aluminum rivet that has been hand set to retain the pin. Once the pizza has been set on the cook floor it only takes a few seconds for the dough to crust up enough to use this tool for spinning. Much easier than spinning with the peel.
    The original idea for this tool was found from a post that Rob from Illinois had shared. He has come up with a clever idea that is working well for me. During my last pizza cook I was doing two pizza's at once no problem in my 36" oven. Normally I do one at a time.
    Thanks Rob, great idea!
    Wayne
    Step by Step of Oven #2 Build... I have built this one in partnership with a friend for a customer that took a liking to my first oven https://picasaweb.google.com/waynebe...42PompeiiOven#
    Re: pizza spinner
    That is such a good idea! Thank you and Bob for sharing that.
    knowledge is contagious, spread the infection!!!
      Re: pizza spinner
      Looks interesting... I had previously seen a peel where the round portion at the end spun, instead of being stationary. For instance, slide the peel under the pizza, pull a handle back causes the metal to turn, or spin and then set it back down and pull out. Hence the pizza never actually moves from the original spot.. it just spins. Alas, I have not been able to find it since.
      My oven (for now):
      http://www.fornobravo.com/forum/f43/...ven-14269.html
        Re: pizza spinner
        Go figure.. I can't tell you how many times I've searched the same words and NOT found what I was looking for.
        YouTube - ‪Pizza Spinner Commercial‬‏
        My oven (for now):
          Re: pizza spinner
          I tool a long metal skewer and bent the tip at a 90 degree angle and it made a great spinner, good handle, and I found it in a camper I bought. Same principal.
